Please Support ExtremePSI
Please Support STM Tuned
How to wire MTX-L simulated Narrow w.o DSMLink
squid267
158
3
Jan 14, 2012
Worcester, Massachusetts
Hey guys I'm trying to finish my wideband install. Currently I have DSMLink v2 and cannot simulate narrowband output via link. I have the O2 sensor in the front spot
The MTX-L has a wire coming from that is simulated narrowband. To which ECU so i splice into? Where do I splice yellow wire into ECU to log?
Thanks
found answer on v3narrowbandsim
Thanks
This is it since the other thread is vague/unsure
You would typically run the narrowband output to the ECU's front O2 input so the ECU could run normal closed loop off this signal and then run the 0-5v output into a different ECU input for datalogging purposes.
