I Y G Josh
- 0
- May 20, 2020
Murrieta,
California
Good evening everyone, this is my first post/thread and if it is not allowed I am sorry and please let me know but, I have a quick question regarding AEM gauges compatibility with ECMLINK V3 on a 1992 Mitsubishi Eclipse GSX. The AEM gauges I am interested in purchasing are the AEM X-SERIES WIDEBAND UEGO AIR/FUEL RATIO SENSOR CONTROLLER GAUGE, AEM X-SERIES BOOST DISPLAY GAUGE: -30IN/HG~60PSI / -1~4BAR, and the AEM X-SERIES OIL PRESSURE GAUGE: 150 PSI / 10 BAR. My question is, are these AEM gauges I listed compatible with a 91-94 ECU (MD166262) that has ECMLINK V3 installed. Also, for data logging on ECMLINK V3 which, ECU pins/wires would I have to tap with each of the three AEM gauges I listed above? Also, I have tried searching for answers to these questions but, could not find any. The only help I found for these questions was for 2g dsms. Also, I have attached a diagram for the 1g turbo DSM ECU Pinouts, I hope its accurate.Thank you.
Links to gauges: https://www.extremepsi.com/store/AE...O-Air-Fuel-Ratio-Sensor-Controller-Gauge.html, https://www.extremepsi.com/store/AEM-X-Series-Boost-Display-Gauge-30in-Hg-60psi-1-4bar.html, https://www.extremepsi.com/store/AEM-X-Series-Oil-Pressure-Gauge-150-PSI-10-Bar.html.
