Dorifto
- 286
- 1
- Dec 19, 2005
Layton,
Utah
Dorifto, your actually going to build your own manumatic system?
Yessir.
Is that Manumatic only for 1gs?
To the best of my knowledge. I would imagine someone has done their homework on the 2Gs, however I've only found info on the 1G TCUs.
The manumatic is for 1g and 2gs...
go to http://www.importperformancetrans.com/mitsubishiauto.shtml#main
They have the manumatic there...
Not quite, but close.
The link below is exactly what I'm going for:
http://www.rmtmods.ca/manual shift.htm
Basically what this setup allows, is a precise shift with full fluid line pressure in any gear. The moment you move the selector, the transmission shifts. Of course, it can be toggled on or off to allow for weaksauce ... er, comfortable ... driving.
Got the selector in "2"? You're leaving the line in 2nd.
In "D" with the O/D button off? You're in 3rd, stopped or moving. [Great for dynos!]
The only drawback to the system as it is currently designed is, that the downshifts are at full fluid line pressure as well, which is bad [broken motor mounts and cracked trans cases are never a pleasant thing]. I intend to build a custom gear selector with a momentary button to disengage the system for a normal downshift, to safeguard against transmission or driveline damage from a harsh shift. Of course, this can also be combated by flat-downshifting, or downshifting while hard on the throttle.
