how long can i go w/out a camber kit?
Well, you should ask yourself how important your tires are to you. You will wear out the insides of the tires you have pretty quickly, making them worthless. So, in your position, I would save up for the camber adj. first and then put it all on at once. My .02.
When I dropped my car I went about a year and a half before putting camber kits on!!!!! BUT i ate up tires like mad in that time frame I went through three sets of tires ......... WHEEWWWWWWWWWWWWWWW alot of $$$$$$$$$$$$$$$$$$$$$$$$$$$ .... so my .02 would say to get your camber kits right away!!!!!!
Are sportlines the 1" drop of the 1.8" drop?
If it's anything less than 1" then you do not "need" a camber kit. Your tires will wear about 10% faster.
With anything in the 1.5" or above range though I *highly* reccomend it. If you have low profile tires then it get's even worse and you are realy oing to be paying out $ until you get one.
And I do hope you are getting some new shocks with any drop. You might get lucky and make it a year or two; or you might hit the wrong bump and blow one. It's all luck of the draw and I'm a man who doesn't like to go against the odds.
its not the camber that eats up tires on dsms its the toe just get your car alined iv got 25000 miles on my lowered 2g tires and thy only show were because i run 30000 mile tires
I dunno how true it is about camber kits and all...i haven't done anything yet..but my friend installed 2" drop goldlines and they have stock suspension and no camber kit and has absolutely no probems with tire wear or shocks blowing out..this car has been dropped for almost 2 years already
