Please Support RTM Racing
2G How Does It Know?
srt4tom
Nov 1, 2012
Tullahoma, Tennessee
On a 1996 Eagle Talon Tsi with a 1g swap,,,How does the computer know how much boost it's getting?
In factory configuration it doesn't. It measures the air mass entering the compressor inlet and guesses what the boost level is based on engine rotational speed. And that is only used for the worthless factory dash gauge.
Thank you for the answer.
How does ecmlink know to display boost?
Its an estimate that's calculated based on either measured airflow and temperature or manifold pressure and temperature, the same way that your factory engine did things.
Thank you very much sir.
That's how all of mine know.
Slap a warning on him so fast it'll make your head spin!!!!
:p
I love Vegas, we have had our fun in the past, right @Vegas smith ??? ROFL
The little boy in the red car with the phrase of "does 40 psi AWD burnout" was a fun time!
We got in trouble for that too, LOL. Right Vegas?? :shhh: :nono: :)
I will try to get a 1/4 BAR map sensor for my measly little snails......
Thank you guys very much for your replies.
it just seemed to me that it had to have a map or something to read the pressure.
mine didn't have the map sensor on the intake, so i hooked one up with a vacuum line.
I know that everyone says it's a boost leak causing it to fall on it's face when it hits boost,,but I've stopped all that I could find with the soapy spray.
Like throttle body was leaking,blowing bubbles,, now no more from that.
the egr was leaking deleted it and blocked it. No more bubbles there.
Injectors leaking,,was,, no more there.
leak down is down to about 1 psi per second,,,I read that was acceptable ,I thought for sure that it was because of no map sensor but just got back from a test and still there,,,,I'm stumped,,,,,Help!!!!
I'm sorry,,the car just bogs down when the boost gauge crosses ""0""
