how do u change bulbs in 1g fog lights
Yea, you gotta unscrew the two mounting screws on both sides of the foglights, and pop it out, then you'll be able to get at the back part of the light to change the bulbs. I did it on mine, and those lights make such a difference compared to the gross yellow looking bulbs...anywayz, it's a very easy and quick install, just make sure you get the right bulbs for the foglights, take one with you when you buy the new ones to match it. ( i had to get the wrong ones before i got the right ones :( )
good luck!
Nate
what do you do if the screws are rusty and just strip? I don't really want to drill mine out, i just want them off, mine are ugly.
that happened to me, i just pulled them out, gonna get a smaller aftermarket pair. now i can see my sidemount! yaya... i no.. front mount this summer...... hopefully.......;)
  • For sale 2g Rear o2 sensor
    2g eclipse rear o2 sensor
    • Dryppical
  • For sale 2g Valve body
    2g eclipse valvebody and solenoids
    • Dryppical
  • For sale 2g Act throw out bearing
    • Dryppical
  • Wanted 2g Eclipse ignition actuator pin
    You must be registered to see element.Looking for this pin that goes into the ignition assembly...
    • Markhamx
  • For sale 2g Ac bracket
    2g eclipse ac bracket
    • Dryppical
