1. Join the Community!
how do i stop fuel cut
Posted by turbojo, Dec 28, 2011
Please Support Kiggly Racing
Please Support Rix Racing
  1. turbojo
    turbojo Proven Member
    155
    Joined Oct 10, 2011
    hazel green, Alabama
    how do i stop fuel cut with this set up GM MAF TRANSLATOR with 660 injectors do i still have to tune the ecu to stop fuel cut?
  2. Bud92gsx
    Bud92gsx Proven Member
    7,999
    120
    Joined Jan 16, 2008
    Wisconsin, Wisconsin
    If you tune the ecu with bigger injectors yes you can get rid of fuel cut.....
    ECMTuning, Inc.
    5K  19  14
    1992 Mitsubishi Eclipse GSX
    13.300 @ 102.400 · 1G DSM
    Loading...
  3. turbojo
    155
    Joined Oct 10, 2011
    so if i use the GM MAF TRANSLATOR it will still have fuel cut?
  4. pneumo
    pneumo Proven Member
    3,019
    55
    Joined Oct 19, 2002
    Bay Area, California
    Fuel cut is still in the ecu code, but with 660 injectors you shouldn't hit it until you're close to maxing out the injectors.
    2K  0
    1992 Eagle Talon TSi AWD
    11.514 @ 118.130 · 1G DSM
    Loading...
  5. turbojo
    155
    Joined Oct 10, 2011
    ok thanks that what i was wondering
  6. rlacasse1
    rlacasse1 Proven Member
    1,830
    8
    Joined Jan 6, 2009
    Scott AFB, Illinois
    Well, you're profile says your mods are stock. So you will most likely just keep on hitting fuel cut with that stock fuel pump.
  7. bryanwheat
    bryanwheat DSM Wiseman
    6,978
    169
    Joined Aug 16, 2004
    Columbia, Missouri
    A boost leak will make you hit fuel cut faster. Also fuel cut had NOTHING to do with the size of your injectors. It's all about how much air is going thru the maf.
  8. ilco187
    ilco187 Proven Member
    1,093
    6
    Joined Jan 3, 2009
    Niles, Michigan
    Well is the maft setup right? and if your using 660s on stock fuel pump your probably sucking the lines dry with those big injectors and the fuel pump cant keep fuel supplied. since you have gm maf and maft its not maf over run.
    888  0
    1993 Mitsubishi Eclipse N/T
    · 1G DSM
    Loading...
  9. NOSLO2PT0
    NOSLO2PT0 Proven Member
    2,002
    11
    Joined Aug 31, 2002
    Joliet, Illinois
    OMG, the bad information is killing me in this thread!
  10. rlacasse1
    1,830
    8
    Joined Jan 6, 2009
    Scott AFB, Illinois
    Well instead of making a retarded post, maybe you should post something that will help him out and point out the bad info. :thumb:
  11. steve
    steve DSM Wiseman
    12,783
    560
    Joined Feb 3, 2002
    St. Charles, Illinois
    How about fuel pumps and fuel in general have nothing to do with hitting fuel cut.
    Fuel cut is that happens when you exceed the programmed airflow limit in the ECU and the ECU cuts off the injectors.
    3K  0
    1991 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
  12. rlacasse1
    1,830
    8
    Joined Jan 6, 2009
    Scott AFB, Illinois
    Thanks for explaining that.
    So when he is using a MAFT you can't avoid that?
    And if a MAFT or tuning allows you to compensate for those injectors and you run out of fuel because of a crappy fuel pump it's not considered fuel cut? Is it just considered going lean?
  13. bryanwheat
    6,978
    169
    Joined Aug 16, 2004
    Columbia, Missouri
    Yes, overrunning the fuel pump would just make it run lean, not cause fuel cut. Fuel cut is a feature in the ecu so that it cuts the fuel when it see's to high of an airflow number from the maf sensor.
  14. rlacasse1
    1,830
    8
    Joined Jan 6, 2009
    Scott AFB, Illinois
    So whenever someone posts about how their car has fuel cut and people respond with "Do a fuel pump rewire" they are wrong?
    That's nice to know.
  15. steve
    steve DSM Wiseman
    12,783
    560
    Joined Feb 3, 2002
    Correct, while rewiring the pump is a good idea it won't do squat for real fuel cut.
    If you have a logger you can tell 100 if it's FC, log the injector pulse width. You'll see it go to 0 when the ECU turns off the injectors.
    3K  0
    manual · 1G DSM
    Loading...
  16. rlacasse1
    1,830
    8
    Joined Jan 6, 2009
    Scott AFB, Illinois
    Ok. Cool, got you. Thanks for clearing that up.
    Much more helpful than the "OMG , the bad information is killing me in this thread!" post I pointed out.
  17. NOSLO2PT0
    2,002
    11
    Joined Aug 31, 2002
    Joliet, Illinois
    After telling people over and over to search what fuel cut REALLY is, you get tired of doing legwork for the lazy. It's not like this is the first or second thread ever made on these sites about this subject.
    And to answer another question on here, the MAFT does the same thing an AFC does. It simply reduces the amt. of airflow the ECU sees in order to compensate for larger injectors. The side bonus of doing it this way...is you get to push your fuel cut threshhold back a bit. Put too large of an injector in (anything bigger than 660s) and the car will run horrible at part throttle, and possibly detonate at WOT, both scenarios due to too much timing advance
  18. steve
    steve DSM Wiseman
    12,783
    560
    Joined Feb 3, 2002
    True Mike but rule 3 applies to both of you guys.
    First for posting incorrect information and secondly for not debating it respectfully, or at least diplomatically, I can't say that your post was really disrespectful. Throwing the retarded word around on the other hand is disrespectful.
    Let's just move on.
    3K  0
    manual · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
