FLASH1970
- 1,264
- 11
- Aug 22, 2005
Lake Geneva,
Wisconsin
First off let me apologize for the crappy cell phone pic of my computer screen. I did the log on my way to work and they're wifi nazis here at work so I took this pic of my laptop at lunch using my phone. I thought WWMD... What Would MacGyver Do. Anyway, my afr map calls for 14.7 and my wideband shows roughly 15.2 when I play back the datalog. How can I rescale the vertical axis of the graph so my afr numbers match the number on the graph axis? In other words, make my wideband graph show 15.2 instead of 151. It looks like the AFRMap line is at 14.7.
In the Graphs & Map Tracer drop down menu at the top there's a "Edit Data Item List" option. Click it. It'll then show everything you can log. You find which item you want to rescale and there's a scroll bar to the right. Scroll down and adjust the "scaling factor". My wideband had a scaling factor of 10 so that's why it was showing 150. I changed the scaling factor to one, and it brought it down to where my AFRMap was showing.
