Please Support Morrison Fabrications
Please Support STM Tuned
2G How can put the hazard button on a switch
jpmxrider489
2,411
146
Apr 4, 2010
pittsburgh, Pennsylvania
I need to relocate my hazard button. I am using a gauge pod that goes in the vents. I deleted all the rear wiper stuff so I only need to worry about the hazards.
What wires could I tap into to put the hazards on a on off switch?
here
look under hazard switch, its pretty messy to hook up a toggle switch, but your best bet, take switch out and mount somewhere else
attached is 2g dsm hazard button, and blinker box, and turn signal switch, there all laced together
here
I was thinking about mounting it elsewhere. But I want it to look stock like it is meant to be there. Im surprised there isnt a wire that just triggers a on or off signal from the switch. I think after looking at the diagram i would need a 4 or 6 pin switch. What did you do with yours? your car looks pretty gutted.
Can’t you extend the wires and just relocate the switch? And just swap to a momentary switch since the oe is an odd shape. Maybe even use a 1g hazard switch since it’s round.
Is the 1g the same pinout as a 2g or at least really similar? That might be the best option since its round.
I would delete the thing if it wasn't needed for inspection.
start video at 5min and you will see my switch location
