Horn Doesn't Work, No Power at Relay, Fuse is Good
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
my horn has not work since i got the car and now ive been wanting to use it lately, so i chased down some issues, the horns themselves are new, the horn pad is good and the contact points on the steering wheel are good. the fuse has power to it but when i went to check the horn relay at the inside fuse panel it has now power, so i jumped power to the terminal for the horn relay and the horn worked, so all the wiring after the fuse box is good. so instead of chasing down and pulling wires apart to find the open in the wiring i want to find the wire that comes from the horn pad itself and run it a 12v source with an inline fuse.
so my question is what wire & what connector under the steering column is for the horn pad itself ?
It doesn't come from the pad, it goes to it. The horn button goes to the grounding point for the horn relay, if that helps any.
yea i know that the horn pad is ground, i found the color wire and connector in ALLDATA, gonna try and fix it today. thanks though :rocks:
