Smileygst
- 1
- Mar 24, 2019
Miami,
Florida
Note: This feature currently requires accessing the site using the built-in Safari browser.
100% correct! Got the alternator replaced and 2 motor mounts that needed replacing as well , talk about a smooth rideSound like an electrical issue, I'd check the alternator first to make sure it's charging properly. Battery and it's connections nexts, making sure the terminals and cables are clean and not corroded, and the battery has a steady, resting voltage of ~12.6 volts.
After that is checked and verified good/fixed, go from there.
