home Surveillance
Put a dead bolt, on your bedroom door. Your worries are over, only way some could break in is back damaging door trim or through your window. That would make parents pissed more.
I've done this and has worked out, since I work 12hrs a day.
If you get a dead bolt use a dremel to make the latch bigger.
I miss the days of hi-tech toys :/
Buy a gun and start cleaning it when he shows up and say oh, i will put this away sorry bout that. Then lock it up and he will be a scared little sissy.
size dont mean shit. Im 6 foot and almost 140 lbs. A 200 lb guy that muscle i can drop easily. mind over matter. Hell on a good day i can lift almost twice my weight.
:hmm:
...And OP, if something gets stolen from you, well you already know who it is, so at least one, and often the biggest problem is already fixed.
The only security a man needs is a nod of his head, a sip of his beer, and a pump of his shotgun as the suspect strolls into the room. If they steal something, well...beat them with said shotgun.
Best Cameras EVER
Night vision Cameras
On another note, you need to be 18 to buy a weapon, but in most states you can buy ammo. Pick up a box of .45 ACP rounds a leave them all over you room.
The threat of an action is most often more effective the the action itself. In your case the threat is perceived not implied.
