Royalty
- 905
- 1
- Apr 30, 2004
norfolk,
Virginia
10. Q. What fluids and other components need to be removed or secured prior to the tilting operation?
A. Remove the vehicle battery to avoid acid spillage and the possibility of electrical shorting should the battery detach from its mount. Remove fuel from the gas tank, fuel lines and where applicable the carburetor float bowl. Although not always necessary, remove the engine oil and tape off the dipstick tube, breather and filler cap. Either empty the windshield washer reservoir or tape it off to prevent leakage. Other fluids such as brake, hydraulic clutch, transmission and differential may remain in place. Secure any loose items in the vehicle interior and trunk.
Geez I gotta drain my entire car before using this thing.
