- Thread starter
- #76
biglady112
- 1,871
- 390
- May 20, 2004
Commerce City,
Colorado
Jeremiah, I used a 4.5" od/4.0" id vband and a 4.5" id vband clamp. I am running a straight 4" pipe out of the fender, so I cannot say much about trying to adapt it down. For the compressor outlet, I got the turbo with the slip on/in hose outlet versus the vband. I did not want to have the thing get here and have it be some oddball vband I would not be able to find with it being a holset. So I went with a 3" 90* Vibrant weld on elbow. AS far as the bolt hole spacing, I just "slotted" the bolt holes in the exhuast housing inlet in a drill press. Oh, and I also turned down the vband outlet on the turbo itself as it was actually 4.7" versus the 4.5" I needed to work properly with my vband ring. I used a large lathe to accomplish this.
I am running a revhard manifold in my application. And just a simple knockoff 38mm wastegate. I ended up not running a spacer that divides the manifold. The person that was suppose to be doing the spacer blew me off again, and after seven months of my manifold sitting down there, I went to pick it up. I am going to run it just like it is. Undivided manifold, divided turbo. Not too worried about it. The 1.6L is going ot spool like crap either way.
And to set the record straight, my friend(the original point of this thread) actually makes FULL boost by 6700. And is seeing boost around 4000rpm. This again, is at 6000ft above sea level. So that means he currently has a 2300rpm window of full power. But the car is moving well long before then.
I got my turbo mounted tonight. The goal is to measure everything and take the intercooler and compressor housing down for welding tomorrow. All my parts came in. Just waiting on the wastegate. That is the last piece.
