hx32w
- 1
- May 22, 2021
Scotland,
Europe
Hi all, I was wondering if you could give some advice.
Ok here’s the story. Sorry for long read. I have a HX32 for an rb25, I had an an10 drain. Discovered it was too small for the holset.
Oil didn’t drain quick enough, and leaked out core. I made up a 20mm ID steel drain for the turbo. I decided to take the turbo apart to clean it as I feared it was contaminated from being in the shed (it was) so i rebuilt it with China kit. After a few mins idling, It leaked oil out compressor side. I later found out the part numbers weren’t compatible (although the parts looked identical ?) I thought ok I will source a quality kit(Mellet) specifically for the Hx32w. But sadly it’s leaking again from the compressor side. You can see the oil coming out the compressor wheel.
I read on mellet they can leak at idle ? but will get not leak if upto engine speeds. I cannot get upto engine speeds as it’s a project and needs mapped etc and bits and bobs. But it didn’t leak oil before I rebuilt it and again it only idled.
I have double checked all the usuals. My Drain isn’t blocked. the drain is basically bang on vertical. I have disconnected the oil breather lines.
It’s an An4 feed. Do you think I should try a restrictor? I know a restrictor should not be necessary though... I’m fed up and on the verge of just buying another turbo but I’d rather not as I’m sure you know a genuine holset HX32 is hard to come by. Thinking of buying hx35 chra and putting my 32 stuff on it.
The current oil level is a little on the low side, however still between min and max. Maybe it needs more oil to build pressure perhaps ?
Thanks.
Thanks.
