1. Join the Community!
ECMlink Here is a question I have been holding back on
Posted by Jamesberry2382, Oct 18, 2019
Please Support STM Tuned
Please Support Feal Suspension
  1. Jamesberry2382
    Jamesberry2382 Probationary Member
    29
    13
    Joined Jul 21, 2018
    Griffith, Indiana
    I have a 92 Talon non turbo 4g63(Its our track car). I am parting out my 92 laser rs(title issues meaning the dash is not from the car) that has ECM Link. How difficult would it be to utilize ECM Link to tune that non turbo car if even possible. I obviously would add a knock sensor, use the engine harness frome the laser, and bring the SD to the Talon.
    456  1
    1992 Eagle Talon N/T
    fwd · manual · 1G DSM
    Loading...
  2. BLACK'98DSM
    BLACK'98DSM Proven Member
    817
    267
    Joined Feb 9, 2019
    Hoover, Alabama
    What modifications have you done to the 4g63? You won't be able to get much out of it if you haven't done anything to it.
    Road Race Build 2K  25
    1998 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    334  3
    2012 Murray Explorer Dune
    rwd · automatic · Misc Vehicles
    250  6
    2009 Troy Bilt Bronco
    Loading...
  3. Dhan
    Dhan Supporting Member
    891
    118
    Joined Apr 29, 2010
    Denver, Colorado
    It is possible to configure ECMlink to talk to the MUT-II in the 2.0L non-turbos. I did it like ten years ago for easier diagnostics. I couldn't write anything new to the ECU cause it wasn't an EPROM and didn't have the ECMlink chip though. I had plans to up the compression with different pistons, run premium fuel, and lean it out to the max in that car, but it just never happened. I unfortunately don't remember how we did it. My dad is the one that figured it out. I texted him but he doesn't remember what I'm talking about at all :idontknow:
    I do remember it being something pretty simple, like right clicking on the desktop icon and editing something in properties or changing something in the preferences tab in the program itself. I wish I had written down what we did.
    It's not a feature I've ever seen advertised by the ECMlink guys, so maybe they don't want it out there. It couldn't hurt to shoot Thomas an email over at ECMlink and with your most humble begging and pleading words just ask him how to do it.
    I'll mess around with the program a bit this evening and if I figure it out I'll let you know. Maybe someone else will chime in with how it's done.
    2K  4
    1992 Eagle Talon TSi AWD
    awd · manual · 1G DSM
    Loading...
  4. Jamesberry2382
    29
    13
    Joined Jul 21, 2018
    Griffith, Indiana
    Cams
    Exhaust
    Intake
    Injectors.
    Squeezing any hp would help tremendously.
    456  1
    Loading...
    BLACK'98DSM likes this.
  5. Mham2k
    Mham2k Proven Member
    174
    25
    Joined Feb 8, 2008
    Dallas, Texas
    I'm no ecmlink expert but it seems as simple as turning the boost control off and setting up the timing and fuel maps appropriately.
    Street Build 351  1
    1996 Eagle Talon TSi AWD
    awd · manual · 2G DSM
    Loading...
  6. Jamesberry2382
    29
    13
    Joined Jul 21, 2018
    Griffith, Indiana
    Thank you so much for the reply. I'm going to install a ECU with link already and a turbo harness. I might just have to run the smallest turbo possible.
    456  1
    Loading...
  7. Jamesberry2382
    29
    13
    Joined Jul 21, 2018
    Griffith, Indiana
    I don't know anything about ecm link I am super new at it.
    456  1
    Loading...
  8. Dhan
    891
    118
    Joined Apr 29, 2010
    Denver, Colorado
    Oh I didn't realize you were going turbo. In that case it should just be a matter of getting a turbo ECU in there with the proper ECMlink chip, the proper proper fuel injectors, regulator, and pump, and other necessary parts. Not sure how much boost you'll be able to run safely on n/t block, trans, and pistons though. The n/ts are a higher compression ratio than the turbo and the trans isn't as stout. You could probably pick up a cheap 13b or 14b turbo though.
    Maybe you already know all this, and I don't know how much time or money you're willing to put into a turbo swap, but it's doable and there's a how-to on this site.
    2K  4
    Loading...
  9. Jamesberry2382
    29
    13
    Joined Jul 21, 2018
    Griffith, Indiana
    I have everything needed to go turbo already. I just wanted to wait as long as possible and maybe be able to learn tuning on our non turbo motor. So I want to install the turbo harness, speed density, ecm link and run a NT car. I have ecm link already
    456  1
    Loading...
  10. CrackedDSM
    CrackedDSM Proven Member
    808
    290
    Joined Dec 17, 2009
    Oak Ridge, North Carolina
    To answer your question, not hard at all especially with the turbo ecu, harness(you don't actually have to change your harness, just add 5 wires to your existing harness), and knock sensor. You may have to do some adjusting to your tables if you're gonna stick with the n/t MAF, but everything else is plug and play. You need a wideband 100% first, but if you have one, go ahead and plug it all up, pull the stock tune off the ecu, copy it and save it, and then start editing one of the copies(leave one untouched to save your ass if anything goes wrong). Your timing tables, AFR tables, MAF hz/etc will all work with the n/t engine, it just will never go into boost. That way once you add forced induction of any sort, you can just edit the actual boost/positive pressure sections of the timing and AFR maps.
    Long story short: With everything you listed, it's 100% easy. Just make sure you have a wideband.
    66  3
    2015 Ford Edge Sport
    awd · automatic · Misc Vehicles
    Street Build 4K  0
    1995 Eagle Talon TSi AWD
    automatic · 2G DSM
    Loading...
  11. Jamesberry2382
    29
    13
    Joined Jul 21, 2018
    Griffith, Indiana
    Thank you for the reply doing the harness is easy for me and I'll be running speed density. I'm running a innovate wideband already.
    456  1
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
