?=help
robs95TSi
May 3, 2003
hi guys! well i have a 95 talontsi and i need a new waste gate
well i have a 1g wga what i need to know is will it work on my 2g
my brother is going to make me a mounting bracket for it but i dont know if it will work.....
thanks robert:talon:
Holy run on sentence batman.
If you used the "topic" feild for the topic, rather than "?=help," you might have better results.
As long as you can fabricate a bracket such that it holds the WGA far enough away from the WG arm so that the rod lengh it right, then you will be fine. Just make sure that the rod barely fits over the WG arm, and that the arm is able to move correctly.
The spring rate may also be different, but that is not really a big deal.
