Help with safc *QUICK*
SilverEclipse18
Sep 3, 2002
Alpharetta,
Just installed an safc in friends car and seem to have problems with it. We have read the writeup on RRE and still seem to have no luck. We can't get the car to idle and it is running extremely ritch. What sensors do we select, hot wire, pressure, ect? The throttle responce is horible. Running stock injectors, fuel pump and t25.
switch the sensor type to "karman". that is the culprit of every problem you have stated. when i first got mine, i turned it on and got a CEL, engine moaned and groaned, wanted to die, and all kinds of funny feeling shit. i had no idea what i was doing, i was just excited. i started going through the menus and found that you had to select your sensor type.
How to install a AFC :
http://www.prostreetonline.com/pso/pages/howto/suprasafc.asp?sessionid=
( yes its for a supra.. use your DSM pinouts where we reference supra pinouts. )
How to setup a AFC
http://www.prostreetonline.com/pso/pages/howto/2gnewafc2.asp?sessionId=
( This is for a SAFC II but the general premise of setting it up is the same. Here are some of the base settings : )
4g63 : etc settings
cylinder : 4 *arrow upwards and to the right*
Throttle Settings : 65% high / 35% low ( what we recommend )
Sensor Type : Karman.
Hope that helped.
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
