88BB8B
- 179
- 18
- Oct 14, 2016
Coldstream,
BC_Canada
I took this motor apart like 2 years ago and I lost my old housing with all the sensors attached still. I forgot what's what on this thing but I did some research and I think I know which holes the sensors go in, I'm assuming it won't hurt anything to block these off for the time being (until I get new ones)I might still be missing some bolts? But This is what my new housing looks like now.
I'm pretty sure the two big threaded holes are external oil cooler ports. Will it be okay to run this with these blocked off? Would it be better to run a hose between them?
Can I run an oil pressure gage off of one of the two plugs on the front there?
Which port would feed most directly to the crank without flowing against the oil pump. I built an exteral oil pump to pump oil in for the first start after rebuilt here.
