spymoto
- 77
- 0
- Feb 2, 2003
Madison_WI
First off I'd like to tell you that my BISS is set correctly. I went through all of the steps from vfaq. Also that I don't have idle surge either.
The problem:
When I went to check my timing with the timing light, I notice that the timing fuctuates alot between 4deg. and 9deg.(a constant back and forth sweep) without the timing check plug grounded.
When it is grounded ( the way you set the timing) it's rock solid at the 5 deg. mark.
Now, from what the owners manual says It should be at the 5 Deg. mark with the plug grounded and 8 Deg. when ungrounded, and their should be no fluctuation if the ecu contoler is working right, but doesn't tell you what to do if it is fluctuating. Like mine is. I looked all over and couldn't find anything to correct this.
PLEASE, If anyone know what might be the wrong let me know.
I just hope that I don't need a new ECU.
P.S. I do have a JDM motor in this car, But has the stock intake on it.
It runs great, but would like to know why the computer is making corrections on the timing.
The problem:
