omgitsjames08
- 0
- May 25, 2006
Tyler,
Texas
I'm really having a hard time figuiring this out.
So my car started idleing at about 2,000-3,000, its been doing it for about a month now.
I looked up on here and it said that it could be because my throttle body was dirty inside. I took it completely off, cleaned everything. The throttle body was very dirty so i figuired hmm it was dirty and not closing all the way. Which was correct, after cleaning it it did close all the way. Then I throw it back on with my "I just showed my DSM to be reliable" smirk.. I was wrong, now my car idles at 4,000-5,000.
The day before it started reaching the 4,000-5,000rpm range my power steering belt broke.. I replaced it the first day everything was fine the next morning it squeaked like NO OTHER its pretty embarrasing. Also the idle is very high making the car sound even worse at a stop with the obnoxious engine revving and the loud squeaky belt. I tried loosening the belt.. Someone said the belt could be too tight.. I tried loosening it. No luck.
I noticed if I leave the car running and push the part of the Throttle Body that the metal wiring hooks up to DOWN then the idle goes to 1500RPM
*I also think the squeaking is coming from the tensioner pully not so much the belt.
what should I do? I really need help.
I also have the CEL that states.. P1294 - Injector Highside Open - Bank 2 / Target idle not reached.
