starfish
- 450
- 2
- Feb 20, 2010
Hamilton,
New Jersey
If it has been sitting for a year, I would def pull out the back seat and change the filter on the bottom of your fuel pump.Also check the condition of your fuel pump.Is it stock or 255?And if you still have stock injectors,throw them in and see if it helps.
? I know that the set I measured were 225cc and the set that Corbin from 2gnt measured were 235cc. Which are both bigger than 19lb'ers. Unless, of course, those 19lb'ers flow more than normal.
