javier347
- 90
- 0
- Oct 28, 2004
Valrico,
Florida
I purchased Ohm Racing Fusebox and Engine harness a couple years ago, I am just now installing these after the car being down for several years.
The problem I am having is that when I connect the battery the interior lights remain on, the SRS and the windshield light all stay on. Now its been 8 years since I have used this car but I also noticed that with out the key being in the ignition I am able to bring the windows up/down and don't think it should work this way. Also noticed that none of the other dash light come on when turning the key to the on position.
I have made sure that the ignition switch is good, I did this by validating that the blower only works when the key is set to the on position, when I turn they key off the Greddy Turbo Timer runs its clock down and the blower stops working. I also turn the key to the on position and made sure the blower was working followed by disconnecting the ignition switch which resulted in the blower turning off.
I have checked all the connections at the driver fusebox and made sure all the fuses are good, I disconnected the light door switches to rule that out. I am really not sure what else I can check here, would def appreciate your guys input on what else I can possibly do to get this sorted out.
One last thing, the car is a 96 and when purchasing a new fusebox from OHM racing you are supposed to send them your original fusebox. I noticed I did not send the original one but instead sent them a spare one that I had for a 97 gsx instead. Not sure if this would be an issue but wanted to point that out since this was my mistake if it turns out to be an issue.
Thank you
Thank you
