Help in diagnosis
kingjust
267
May 23, 2006
Orlando, Florida
Symptoms:
Cannot go into gear while motor on.
Can go into gear while off.
While in gear when the motor is off, with the clutch down, the clutch is still engaged and when I try to start the car moves. (This is why I think now it is the pressure plate instead of the synchros)
At first I thought it was the synchros until I realised that I can't start the motor with it in gear and the clutch down, which it should start. The clutch master cylinder was replaced and bled.
So, i'm torn between synchros, clutch fork, or pressure plate. Everything else seems fine.
What say you all...
