13secGST
- 1,111
- 2
- Dec 1, 2002
San Luis Obispo,
California
Ok I was flooring it through first (I have a big16g so you know) and it was kind of bumping cause of the road, it had slight dips in it that made the rpms jolt a little. Once I was at around 7K I heard a pop and I shifted to nuetral slowed down and it kind of idled funny like it was a little bouncy and almost stalling. I went into a McDonalds parking lot and under the light I looked for any IC pipes that may have popped off which has happened to me before. But after looking at all of them I didn't see anything wrong. I also looked at my boost controler hoses and things going to gauge. Everything looked normal. So then I turn the car on still idled kinda funny and started to go then I hit it in first again and it just wont go into boost and doesn't really like getting above 3K rpms if it means boosting to get there. also when I started to get ~5psi the car kinda did a slight jolting and stuttering like it was getting to much gas or too much air or something. I manage to get 3psi to feel like it was not a problem going up a long hill and also got up to 3500rpms in 1st taking it slowly.
Well thats a complete diagnosis of everything I know as of now...If anybody has ideas of what this could be please let me know. Also if you would like me to check something else that I haven't mentioned to help you figure out a solution I can do that as well.
BTW after driving home the car now idles fine. I'm thinking this may be a boost leak but I'm not sure. Also my IC pipe set is as follows J-pipe, home depot ghetto setup, modified stock lower IC piping, Stock Sidemount, Short UICP, After BOV is stock UICP
