stevecbr929
- 146
- 1
- Oct 21, 2007
Marina,
California
95 2g Talon TSi 186,xxx miles & all stock except non-recirculating bov, & injen intake.
All started about 1 month ago - making the 1-2 shift & the engine just stopped - lights on, no engine. Towed back home, found balance belt in pieces - took out crank sensor & sensor blade of course. Did a compressioin check after it wouldn't start after replacing belt. Bent valves.
So, new head, carefully installed w/forum (thank you), & dsm shop manuel as guide. Did compression check once all was complete & all 4 have decent compression.
This is where I have no idea what's up. I tried to start & when it did, it shook REALLY bad, make a "squeeky" noise (vacuum?) sounded like it was in the throttle body area(?). When trying to start (I've since stopped trying), the starter will turn 1 or 2 times, then sound like it's hitting a big resistance and stops.
HELP!! Totally stuck & screwed without my car - thanks....
