gtrej01
- 406
- 22
- Dec 13, 2010
Granger,
Washington
Ok, I would like to have some help in diagnosing my 1g. Please see my mods in my profile. Car is running on E85.
Car ran fine prior to taking it to the track last Wednesday. This was my first time racing it since I bought it last month.
I was told car has ran a best of 11.3 before.
1st run I ran a 13.0 then a 12.7. Boost held strong all the way on both passes. on the third pass It began misfiring/ sputtering under boost ans blowing dark smoke out the back.
I checked out the car and turbo is healthy with no shaft play what so ever. I did a boost leak test at 30psi and only heard a hissing sound coming from the Throttle body. the hissing sound got louder once I opened the throttle a bit by hand. Is that normal or does it need a rebuild?
I put in new Spark plugs to see if that was the issue and still the same.
Any help is appreciated on getting the car back running normal.
Please help!
Please help!
