TRBOGSX
- 0
- Jan 23, 2003
Here it goes.... I have a 2g GSX that i put a 1g intake manifold and throttle body on. I was just wondering what I should do about the electrical connections that go around that area such as the MDP sensor (on top the intake manifold), TPS, Ingition Coil and Power Transistor and the Idle Air control motor. I dont know if the wiring connections are the same and if it is possible to use the 1g sensors instead. Also i dont know where i could mount the 2g MDP sensor on the 1g intake or the Ingition Coil and Power Transistor from a 2g car. Just looking for a lil help with this mod...thanks for the time.......
