1. Join the Community!
Hello from northwest ohio
Posted by Ttshovel, Jun 16, 2019
Please Support ExtremePSI
Please Support Southbay Fuel Injectors
  1. Ttshovel
    Ttshovel Probationary Member
    Joined Jun 16, 2019
    findlay, Ohio
    What's up everyone. I'm from findlay, Ohio
    I've owned a handful of dsms over the years and looking to start a rwd swap project using the 4g63 platform. Something light and 4 doors to make a fun street car out of. Looking to make 6-700whp. I was looking into 1st gen crvs and rav4s
    Currently have a 2012 Camaro that I just "finished," still working out the bugs. Iron 6.0, th400, Ford 9 inch, big tire car. Single 94 mm on e85. Makes just over 1000whp.
    Also have a a big tire s10 that I'm in the process of finishing. That's powered by a gen1 sbc/th350, 12 bolt rear.
    And lastly a 1972 chevelle that's just a driver
  2. motomattx
    motomattx Proven Member
    1,654
    459
    Joined Dec 9, 2010
    wampum, Pennsylvania
    Nice rides man!
    Drag Race Build 2K  16
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  3. ThunderChild
    ThunderChild Supporting VIP
    2,437
    645
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Welcome! Sounds like you know what you're doing, I look forward to the project, and I second the sweet rides!
    It'll be interesting to see a rwd 4 door 4g setup, don't see many ppl going for the sedan!
    Are you going to use bill hincher or buschur for a trans adapter, or make your own?
    Street Build 117  3
    1990 Plymouth Laser N/T
    fwd · manual · 1G DSM
    234  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 746  7
    1997 Mitsubishi Eclipse Spyder GST
    Street Build 950  1
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 2K  10
    awd · manual · 1G DSM
    Loading...
  4. Ttshovel
    Joined Jun 16, 2019
    findlay, Ohio
    Thanks guys and I plan to use one of those two adapters. I really want to use a 4l80e trans behind it for the overdrive and pick up a cheap Ford 8.8 or 9 inch out of an explorer for a rear end.
    I definitely want 4 doors and something I'm not afraid to drive across the country. I really want to hurt people's feelings so a wrx/sti is high up on the swap list as well. I'm open to other ideas as well. The lighter the better hence the first 2 listed, one being 2800lbs
    ThunderChild likes this.
  5. ThunderChild
    2,437
    645
    Joined Jan 5, 2012
    Rathdrum, Idaho
    I vote for an 80s ford LTD or an 80s Camry for full sleeper effect :cool::cool::cool:
    Street Build 117  3
    234  8
    Street Build 746  7
    Street Build 950  1
    manual · 1G DSM
    Street Build 2K  10
    Loading...
  6. Ttshovel
    Joined Jun 16, 2019
    findlay, Ohio
    I could definitely get behind that camry! I'm a big fan of the g body malibu wagons but not sure on weight of one! Not having the torque I'm used to leads me to keeping it light!
    A buddy has a good condition 6 bolt shortblock for 150 but thinking itd be cheaper to just get a complete motor and salvage what I can. Im open to the revised 7 bolt motor as well...Thoughts?
  7. ThunderChild
    2,437
    645
    Joined Jan 5, 2012
    Rathdrum, Idaho
    Either one or any can be built just fine, if the 6 bolt isn't complete you'll have to hunt down a bunch of stuff which is tedious and adds up. I'd vote for finding a complete engine for sale so you have all the little parts you might need, 6 bolt or 7 bolt (split thrust or not) isn't as big of an issue if it's built correctly anymore. If you want to retain piston squirts then 6 bolts are good from the start, but a 7 bolt could be machined to accept the older style and you can plug the new ones, but most aftermarket rods will have a squirt port or two in them as well. The 7 bolt head is where it's at though, or you could do an Evo/Kia head for new style and best flow, plus Evo 9s have MIVEC if you want variable valve timing.
    A 3rd gen block (revised split thrust) with a Kia/Evo head is going to be my RWD setup later on.
    The Camry I can't remember or find the curb weight of, but after working on it, I'd estimate it's maybe 2400-2500#, if that. Honestly with the power level you're looking at and a good auto, I wouldnt worry about the weight. You can get a good converter and brake boost if needed and it'll be a rocket ship even close to the 3k# mark as long as it'll hook up.
    I think the g-bodys will be a bit heavier, but it'd be sick to do one with a wicked 4g, and it'd take far less fab work.
    Could also do a bimmer for a 4 door that's light but still has rwd layout, and isn't too bad on weight, not to mention most of the handling parts from the sport cars will still work. 86-87 325i 4 door would be sweet.
    Street Build 117  3
    234  8
    Street Build 746  7
    Street Build 950  1
    manual · 1G DSM
    Street Build 2K  10
    Loading...
  8. Ttshovel
    Joined Jun 16, 2019
    findlay, Ohio
    Awesome, good info. Thank you. This is a project I'm looking to start this winter after I finish my s10. It doesn't need much. Rear tires, front coilovers, and driveshaft. Then source a shell to start on. My Camaro I'm using ms3 for engine management so I'd like to use that on the 4g63 as well. I'll try to remain active until I have something set in stone for the project
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned VR Speed Factory WheelWell.com White Shed Speed
