Please Support ExtremePSI
Please Support STM Tuned
headgasket and head studs
forcedfedgsx
183
Apr 29, 2003
OhioUS
i have a 95 gsx with a rebuilt bottom end and a 1g head will the normal 2g headgaskets and bolts work to replace mine. which ones should i get i want to get some decent stuff prob arp studs but need to know if they fit and what kinda gasket what price should i pay
i dunno if they are the same gasket or not, but i got my headgasket from the local mitsu dealer for 50 and the arp stud kit for 90 or so from slowboy
Head gasket is the same through all 4G63 runs.
Clean off your block and get a stock mitsubishi headgasket. Unless you warped the head/blew the headgasket/etc, use a stocker. 4 layer meal HKS/Mitsu brands aren't needed, because your geometry should still be good.
Id go for a stock gasket with ARP studs. This setup has gone 10s and is fine. Another issue with metal gaskets is sealing issues and pushing coolant.
it overheated and blew and my head prob will need milled so i should go hks then
Go with a cometic head gasket. They are to be of the same quality of HSK but half the price.
