90turbotsi
- 246
- 4
- Sep 15, 2002
Owings Mills,
Maryland
I just finished my head swap after my 5K OEM belt took a crap on me and took out my motor. While I was in there I properly wired up my electric autometer oil pressure gauge. I never noticed any abnormal oil pressure with the stock gauge but figured to be accurate id get a real one and such.
I have the sensor in the front port of the 90 oil filter housing, the one which was plugged up and requires a allen wrench to get out. When I started my car and let it run for a while I got in and looked over a few things. The oil pressure at idle was 20-40ish psi depedinging on the rpms from the cams and at this point my poorly set idle. Once I gave it gas about 3000 and on rpms it jumped very close to or up to 100 psi. I am no ok with these numbers at all since I know this is going to kill my turbo seals and all the other misc parts. The motor has no balance shafts and I never ported the oil relief during the build (sadly it never crossed my mind or I would have. The motor probably has 5-6k on it max and im sure was driving with higher pressure before since little changed other then the turbo. Will porting the oil relief lower the pressures that much/enough? I know with out the balance shafts I will see higher pressures but im just concerned... I dont want to kill the motor and the brand new 20G on the car. I was all hyped to drive the car again since its been down quite a while due to lame vendors I had to deal with and my slow machine shop. Its probably not smart to drive it much tho so I wanted to get some opinions on the car.
