td06hkiko
- 120
- 0
- Oct 23, 2003
San Diego,
California
Ok here we go. I normally run 15psi on low boost and 20-22psi on high boost. I tune with pocketlogger. And I have checked for boostleaks. I have already pressurized the intercooler system along with the intake and no leaks. Now the problem is, boost over 15 psi car starts to stutter? I tried hi boost and right now wont boost over 16psi. Could it be the WASTEGATE ACTUATOR? Or the 34mm flapper? Turbo is still new no shaft play and spins freely. I did find the vaccum hose connecting the actuator to the boost controller starting to crack from the heat. so I changed that. Still the same problems. Anyone wanna take a shot at this one.?????
