Car_guy_09
- 2,690
- 0
- Aug 4, 2007
Wilmington,
Ohio
Ok so i just bought this car and it is the 420a and has the hahn stage 2 kit with super 20g with frontmount kit and everything. Well the problem is the regulator is acting like its not sensing boost so it dont turn up the fuel pressure, which causes the car to run extremely lean under boost but a/f is good out of boost (like 11.9-12.5) but if i start boostin it it starts leaning out as boost builds and get dangerously lean (like spikes to 16:1!!) and thats only at a couple psi. And i didnt get boosting it just so you know im not that dumb once i seen 16 on my wideband i decide to stay out of boost on the way home with it I was looking at the vacuum lines and they look a lil weird the way they are running and the guy has a MBC sitting on a intake pipe which i dont like, But what really scares me is there is what looks like a vacuum connection on the regulator that has nothing hooked to it! Is that normal?? If possible i would like to get a diagram of the way the vacuum lines are supposed to be ran to see if all that is hooked up rite. Rite now i got the car pretty much parked in fear of melting the pistons or something So please help me with this regulator so i can get the car running good
