Please Support JNZ Tuning
Please Support STM Tuned
Having problem with figureing out why my GST is stutering
SlowdsmGST
188
Jun 27, 2005
Jacksonville, North_Carolina
It seems that everytime I jump on it my car stuters around 3500 to 4500 RPM. I have recently replace ing. wires and spark plugs. I believe it is a coil but not sure. The car only does it once in awile or when I get on it and on happens when the car is in low boost. I have though that it was just plugs or wires because I have had miss fire in cyclinder 3. So now I am at that point where I am tired of spending money so if some one could help I be a happer DSM owner. :dsm:
What kind of wires are you using and what kind of plugs? I had the same problem and i swapped out my plugs to the NGK Bpr7es and it doesn't do it at all. If your still on stock boost level then you should try the BRP6es. Hope this helps.
Denzos Irinums with Bosh wire nothing to big. I think the plugs are causeing it my self but the car is just accting odd :dsm:
Only run NGK plugs on turbo DSM's
