Has ANYONE tried this!?
Puller
269
18
Feb 7, 2003
Atlanta, Georgia
I want to vent my bov to atmosphere but i know it causes probs with the MAF...however i found a kit which places the MAF after the BOV and before the throttle body on the upper ic pipe. has anyone tried this and let me know how well it worked for you...thanks. ps. if u get the kit you would have a GM MAF translator as well as a 3-3.5" GM MAF sensor on the upper I/C pipe...lemme know...thanks...
It's the Ramcharger MAF translator system.
And yes, if you set it up as a blow through system you can vent to your hearts content.
yup, i have the exact setup you seek....but dont get it just to vent. thats very purple guy. get it to tune your car, a good side effect of it is that you can vent to the amosphere with a blowthru setup. you also should get a datalogger to tune the car.
if you actually want it, read all 600 posts in the thread about it.....
also, i am not exactly sure here, but you should still recirc the BOV unless you crush/mod it b/c it'll leak on you. this leaking will make the turbo try harder and harder to push boost and BAM, turbo = dead
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
