harder to start now...need some help
JayB98GST
72
Aug 20, 2002
I just installed and rewired a walbro, afpr, and new plug wires all at the same time. Since then it is now a little harder to start the car. I have to crank it for a couple of seconds if the car has been sitting off for more than like 15-20 minutes. Even if I shut it off and start it up right a way, I still have to crank it for a little longer than I should have to. Anyone have any ideas why its doing this now?
Sounds like the cylinders are still getting fuel, even though the car is turned off. Pull your plugs and see if they are burnt or if they smell like gas.
Maybe you wired the fuel pump wrong?? It might be staying on after you shut your car off, running off the battery, but I highly doubt that. Check your spark plugs.
  • For sale 4G63 Parts
    Transmission starter plate fits 2G DSM 7bolt engine for Auto AWD or FWD and FWD Manual...
    • Dsm_canadian_mike
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
