ninja07
- 51
- 0
- Dec 7, 2009
antioch,
Tennessee
I've got a '95 awd Talon tsi. It is fairly hard to shift into gear when sitting still. It's also a little hard to pull out of gear when sitting still. And when I'm driving and shifting, it takes it a second to shift up or down all gears...........Could this be my gearbox?
New parts:
*New oem clutch kit, w/ 11.5 lb chromoly flywheel
*reinforced clutch release fork from MachV Motorsports
*pivot ball
*Hurst short shifter
*ss steel clutch line
*oem master & slave cylinders---------(bled and adjusted)
*brass shifter cable bushings
*nylon shifter plate bushings
Note: It was hard to shift before all the new parts, I was hoping these parts would improve the shifting, but it has made no difference, except a shorter shift throw... Any advice would be great, thanks....
New parts:
*pivot ball
