Resolved Haltech elite 2500 Standalone ECU?
Donv
37
5
Jun 11, 2021
Parkville, Missouri
This might be a dumb question but could I use the haltech elite 2500 from a evo 8/9 on a 2g gsx?
Solution
That is the only one you can't use. You'll need the Evo 4-8 PnP adapter.
I know it says 1500 and not 2500. But if you check the quick start guide on the product page it supports both as stated in the Application Notes section.
You can also use the same Plug and Play adapter for both the late model evos and 2Gs. There are a few configuration jumpers you change but it is very straightforward.
Solution
Thank you🤝🤝
