1. Join the Community!
420A Guess the HP. Give me an estimate.
Posted by BLACK'98DSM, Jan 9, 2020
Please Support ExtremePSI
Please Support STM Tuned
  1. BLACK'98DSM
    BLACK'98DSM Proven Member
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    I'm going to look at a turbo'd 420a car on Saturday. I know this is a long shot but I was just wondering if anybody would know how many horses this car might be pushing.
    Mods:
    - 63mm turbo
    - blow off valve
    - catback system
    - 550cc injectors
    - cai
    - Big Blox throttle body
    Road Race Build 2K  23
    1998 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    481  5
    2012 Murray Explorer Dune
    rwd · automatic · Misc Vehicles
    378  4
    2009 Troy Bilt Bronco
    Loading...
  2. Widgmaster
    Widgmaster Supporting VIP
    36
    77
    Joined Aug 24, 2018
    Sarnia, ON, Canada
    Hey Black … Just wondering if you ever heard of a program called Desk-Top-Dyno. You can feed all your info into the program ( you can even estimate 1/4 mile times ) and it will kick out your HP curve . I had it once before when I was bracket racing and it does a pretty fine job . You need to add loads of info such as weight , tire size , your weight , temperature , altitude ECT . Gives a pretty accurate reading too .
    33  1
    2002 Dodge Dakota Extended Cab
    141  7
    2001 Mitsubishi Eclipse Spyder GT
    fwd · automatic · Misc Vehicles
    Loading...
    BLACK'98DSM likes this.
  3. lasthope05
    lasthope05 Proven Member
    936
    215
    Joined Mar 31, 2006
    Philadelphia, Pennsylvania
    I'd say no more than 180-200whp.
  4. BLACK'98DSM
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    On a 63mm turbo? The stock 2g turbo for GS-T is a 41mm... And 550cc injectors can handle 315 hp @ crank, which is about ~290 whp.
    I'm just curious why you think these numbers are what you guessed they are. I'm not saying that you are wrong, just asking why you think you are right.
    And I guess it would help if I told how much psi of boost it was pushing...
    481  5
    378  4
    Loading...
  5. red_devil
    red_devil Proven Member
    961
    49
    Joined Jul 13, 2005
    Cape Coral, Florida
    With the lack of information you gave us 1-1000hp.
    2K  9
    1995 Mitsubishi Eclipse GSX
    manual · 2G DSM
    Loading...
  6. BLACK'98DSM
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    That's all the info I have. I can probably get a detailed write-up from this guy, but it's not worth it. I'm probably going to end up buying this car anyway. And then I can do some tweaking and dyno it myself. :)
    481  5
    378  4
    Loading...
  7. silvreclips
    silvreclips Proven Member
    1,065
    239
    Joined Jul 19, 2005
    Greenville, South Carolina
    Is the motor built or stock? Either way the 550cc injectors will run out way before the turbo does.
    Autocross Build 269  1
    Loading...
    BLACK'98DSM and tk106 like this.
  8. tk106
    tk106 Supporting Member
    2,073
    629
    Joined Sep 11, 2017
    Cincinnati, Ohio
    That'll give you a round about idea of what it's making/limitation.
    218  3
    2000 Jeep Cherokee Sport - Classic
    awd · automatic · Misc Vehicles
    205  4
    93 Civic 4 Door -sold-
    fwd · manual · Misc Vehicles
    Street Build 2K  6
    1992 Eagle Talon TSi AWD
    12.625 @ 111.42 · 1G DSM
    Loading...
  9. Kai Hefner
    Kai Hefner Freelancer
    242
    107
    Joined Jun 21, 2018
    Calgary, AB, Canada
    Along with everyone else, it's hard to say without more info. Assuming the injectors are MAXED out, I'd say ~290hp.
    Again, it's hard to say.
    Edit: Also if it's not built, it'll be way less. Pretty sure stock, boosted 420a cars blow up under 300hp or something around that guideline.
    Street Build 414  1
    awd · manual · 2G DSM
    Road Race Build 682  2
    1998 Eagle Talon TSi AWD
    Loading...
  10. lasthope05
    936
    215
    Joined Mar 31, 2006
    Because the car isn't built and most likely will be running low boost. 7-8 psi. It's also probably also isn't tuned. Those motors and transmissions dont handle power well stock.
    Doesn't matter what the turbos inducer is or what size injectors it has. It's irrelevant in this situation with a minimum effort build or lack of information. Don't automatically assume what the injectors and turbo is capable of is what the motor is actually putting out.
    Honda guys do the same thing. Huge turbos, small injectors, low boost, substandard results.
    Also stock the 420a only make around 100-120whp so it's not a far stretch.
  11. streetraceboi
    streetraceboi Proven Member
    419
    90
    Joined Sep 4, 2002
    San Antonio, Texas
    150hp
  12. BLACK'98DSM
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    I don't know, he doesn't give much info.
    I will post a link to the ad tonight so you guys can look at it.
    481  5
    378  4
    Loading...
  13. Evolving_sti
    Evolving_sti Proven Member
    81
    53
    Joined Apr 28, 2019
    DANBURY, Connecticut
    I was gona say the same. It's not a stout motor and Its only 140 hp from factory. dont see anything crazy coming from it if it's not built. And I dont think many people even bother building these right? Could be wrong.
    170  3
    1999 Mitsubishi Eclipse GST
    211 whp · 268 lb/ft · 2G DSM
    Loading...
  14. kenuwine4g63
    kenuwine4g63 Proven Member
    472
    29
    Joined May 26, 2009
    Charlotte, North Carolina
    If its tuned on low boost, 240-260hp.
    If its built head, block and more boost maybe 320-340. Just depends on a lot of variables.
    If its just turbo'd with no tune and a FCD then it probably makes around 180whp.
    kenuwine4g63
    399  0
    1995 Mitsubishi Eclipse GST
    000.0 whp · 000.0 lb/ft · 2G DSM
    Loading...
  15. BLACK'98DSM
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    Thanks guys. Looks like the deal isn't going to work out anyway.
    481  5
    378  4
    Loading...
  16. Evolving_sti
    81
    53
    Joined Apr 28, 2019
    Wat happened?
    170  3
    Loading...
  17. BLACK'98DSM
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    I got in contact with him. He said that the engine has never been rebuilt, stock rods, stock pistons, stock ecu. He said it idles high because of the ecu. He also said that the turbo was from Ebay. And from detailed pics the engine bay looks really nasty, possible corrosion and fluid leaks.
    Even if the car was magically great, it is 5 hours away, so It's not even worth my time to go and look at it.
    481  5
    378  4
    Loading...
  18. Evolving_sti
    81
    53
    Joined Apr 28, 2019
    5 hours isnt to bad. But yea that sounds terrible. Running boost on a stock ecu? No thanks
    I drove 8 hours for my evo. If your willing to travel, theres a nice red gst I just saw in the classifieds. Guy wanted 3k for it. It looks pretty clean. Might be worth a look or get it shipped.
    170  3
    Loading...
  19. BLACK'98DSM
    1,278
    427
    Joined Feb 9, 2019
    Hoover, Alabama
    It's really not that bad, but it is not worth driving that much for a POS ROFL
    481  5
    378  4
    Loading...
  20. techboy
    techboy Proven Member
    297
    145
    Joined Feb 3, 2018
    Lehigh Valley, Pennsylvania
    I drove a turbo'd 420A with a forged bottom end and built head for a number of years before making the switch to the 63 platform. It was a lot of work and a lot of money for not a lot of result. Probably best the deal fell through.
    That said, there are a few guys around doing it, and I commend them. Definitely the harder way to go.
    Street Build 2K  6
    13.876 @ 106.97 · 2G DSM
    Loading...
    Evolving_sti and BLACK'98DSM like this.
  21. Evolving_sti
    81
    53
    Joined Apr 28, 2019
    Curious but what was the turbo setup and hp on it? Was it reliable when it was all said and done?
    170  3
    Loading...
  22. silvreclips
    1,065
    239
    Joined Jul 19, 2005
    @Evolving_sti there are still a few of us hanging around here. I put down 340whp on a 20g. Built bottom end, refreshed head, stock cams etc, megasquirt ECU.
    A well built system will be reliable.
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
