shellhouse
- 103
- 38
- Nov 8, 2021
Atlanta,
Georgia
That's awesome, I'm jealous. People won't understand how fun these are until they ride in one. Something raw about them also, especially compression lock on downshifts.
Hello. Very awesome. Do you have a part # for that oil cooler fan?Well, I have forgotten to continue updating this again. So a quick, very important update, I believe I am ready to get the car started tomorrow and take it on a quick break in run. Eventually I will go back and finish the updates...maybe.
Confirmed oil flow to the head when it was on the engine stand. Took the plugs out and cranked it yesterday. It had oil pressure and oil made it to the rockers so there is that.
Oil cooler for the 90 OFH.
Just keeping the hose and cooler closed. Eventhough a bluetooth oil cooler would be cool. This cooler has the fan that will be controlled by an inline thermostat. Incoming oil temp goes up, fan comes on.
Too thick radiator installed.
All of my gauges. The upper pod and radiator delete pods are of my own creation, then 3D printed in ABS.
We start tomorrow!! (Disclaimer: Unless the couple things I have left to do prevent that. I also still have to clean the garage up a bit to get the car out so that might take a while.)
Thank you.It came with this kit. Derale 15850, is the P/N for the kit on summit racing. I don't see where they tell you the fan P/N.
Well that is interesting. Is it their power steering fluid or still some kind of ATF? I will gladly add it into the electric pump.Great job with the car!
Switching to redline fluid remedied all my power steering cut issues.
Sweet, I'll grab some. I have a buddy who is also jumping to big slicks this season. I will have him use it in his with the stock power steering pump and see what happens (read as Guinea Pig)EXTREME PSI : Your #1 Source for In Stock Performance Parts
www.extremepsi.com
"RED LINE POWER STEERING FLUID satisfies the service fill requirements of most auto manufacturers and can be used where the manufacturer calls for any automatic transmission fluid"
