1. Join the Community!
GSTwithPSI's Virago Cafe
Vehicle:
1982 Yamaha Virago
Please Support Kiggly Racing
Please Support Feal Suspension
  1. GST with PSI
    GST with PSI DSM Wiseman
    1,816
    1,349
    Joined Jul 27, 2005
    San Diego, California
    I sold off all of my bikes a few years back, and have been itching to get back on 2 wheels since I moved back to SoCal about this time last year. After seeing a bunch of cool cafe builds in the interwewbs, I've had the itch to build something that feels like it's my own. This thread is my attempt at building something cool, with also sharing it with you all.
    I started the search for a donor back in June of this year (2018). I've always liked the Virago, and like it even more when turned into a cafe. The mono rear suspension, shaft drive, and overall availability were all factors in choosing the Virago. My Dad also had one when I was a kid, which added a nostalgia factor.
    Anyways, after searching for a while, I finally found a donor on OfferUp. She was in rough shape from sitting for who knows how long in the previous owner's back yard. But, it was bone stock and intact, so I pulled the trigger:
    zIsa4ZUTHU0vRg1DISPE7BxswpMwIrUmTfsc9qXrvuToqozk0k_wd3E06hsdYOzTeMCbQVLJreuE2HDDMS4=w848-h626-no.jpg
    kLVkt3XqNscB1BNZJfGBv00v7r7TCf6QJx-Src74aG3UXZ7e1-h0kFs9wLzkBXYyMBdjCpignMbF8-eHxJM=w470-h626-no.jpg
    After a short haul, I got the bike home and rolled it into the garage on flat tires (which sucked ass):
    449Ddkvqn9CLuFSj1-eUg9Nv2u-FJ9rOMbrVoVrc5gljDmo0o4VGsk-Y62HTmszFt8gA6xMlQhFWMOdR4U8=w353-h626-no.jpg
    75loVcFLRkZNMRGb2AchgRILH84EcDfl-fSZ6y8O8BxXdnHe8qCo5D8VIL2EJeDjsBHfBjxdxFhHYqwoF0=w1006-h566-no.jpg
    zGKJWBNalrFvb61yuk_VkRy-fc9OnEnwQcjBBPG_3Pzec2nIzpHjvm6M5cPJ4PeFwu4KtUPe7cF28iPvH8=w1006-h566-no.jpg
    gGfpT7Qx5V5Kv7aT39q0YMTsnqc5jlvAidqjGrF12j5XMMluTZ0v-utGit9a5tljUnj48k9JInxbjNIKJQ=w1006-h566-no.jpg
    Once in the garage, I got to work! I started by stripping off all the 80's :): :
    JmY-5URk1nl20yXdFDnaCo9IeOGYYleDUyrXmnVHF9UW83I_-jKLo-NAAhpdXx4nkl3xwpm2cSRXB5a4js=w1006-h566-no.jpg
    BhegeG_krOQzunvJzDmpGggnfadoQgujaoHMVYAJ9WKXb_SXX0wiOBGTPk3gFWDdoHBQk0JeduNbkStpvw=w1006-h566-no.jpg
    Next up was a front end swap. I got a set of 05' Bandit 1200S forks, which were almost a direct swap. For better braking, I also added dual 3 pot Tokico calipers from a 99 GSXR 750.
    jetgUm5NdF5LHTixfCvzEc1qPROT6EHmlXIWQ94Sh9UxBzY54QOq12mNHPnXk8Wbc5Ely4KkiMGh567SxS4=w353-h626-no.jpg
    4ElJvw1NIGBrrZhgx75FizQ9SwCUKspU1c8zcnzAoRAmOCa9Ek5pNC7aNzkg3NonlZ1b9oW-3kSUT1rL5Q=w1006-h566-no.jpg
    bvZFLYBuV5l08JyhjyqXWKgbj71tOwm6kLP79pzwPa1HOt8THk6fPcg2yKbeUsBE8eYO--tjT2BcFzqOsU=w1006-h566-no.jpg
    lUocVC8IRDaZ1VqpdsQVs9Qh9R0WKiPvDjka6cXoyYDhfBIbWcukN0df9pdyhzy9gO9K9F3-lDGuxfr0wE=w1006-h566-no.jpg
    The tank was pretty crusty, so I went to work removing the internal rust. Sadly, during the process, I found the rust issue was worse than I initially thought. I found some holes in the bottom, so I sourced another used tank and repeated the same process, which essentially entails filling the tank with Muriatic acid and nuts, giving it a good shake, then rinsing and repeating until clean.
    Tank #1
    i8uXIw9FsWgraYbWvvCLFWvfU_HwxZ8ZknEolsmBT3hXu60T532IMcxeBDBnWsiIBVn_T8Qp_2mhx3sPopk=w353-h626-no.jpg
    AbUw4rQ0c1oDR2ssvu_eR0g44ZAVQFZ_phDLHMGtQ_5XWj4VFikVGvnlrB7F_HZ0oEJ_7ZeyY46kn9JbQQ=w1006-h566-no.jpg
    EJnFZHrZSCjxmvdJp7WUrHiwPuGyZfVADjb18pz19v-PQ-dpkiEd0dASKKvgb-SzUDLobjp2qsexGQLuwo=w1006-h566-no.jpg
    Second attempt on tank #2
    D1Ngksk3UOYlVvzgv1QHUmV-LpnE0ogiK_9_MxDQ4E9qpJ1gKVfcewb_N8GSeEPr8s86a4sWHnbo4A-sTk=w1006-h566-no.jpg hwmU8OJQ66dTwVurzndgyHgn8jNILbKZrTowZWTZ52wlkUXQdOHRxqzhZmU3J61vmrBs6bqOU0I9zFhEN8M=w353-h626-no.jpg HVO1BF8l1zDTxsLcUm54OwNAMfwXTxkoF3ZkwkhGmNW4OwY1seRVhFLg0NAA-62tmip-xdNRixjKD9ftFY=w1006-h566-no.jpg uPvgGSzuqQC_hKxTOht93rcog7iV0xReUCA0_ST1OEqzmcZdxvXcWyhcN8GjHQC2D2T4V1Sagz9hLnJWtLo=w353-h626-no.jpg R6jupsZ-9Vm0waHF5dlZEzF5Dit1-kqgTTtEHOFxY3LReY7i7fNmZ8EnRBmmE-2eIrWUDIBAg2AXjJMkjzE=w353-h626-no.jpg
    Street Build 26K  18  143
    1991 Mitsubishi Galant VR-4
    12.030 @ 119.39 · Galant VR-4
    864  23
    1982 Yamaha Virago
    rwd · manual · Misc Vehicles
    Street Build 5K  74
    1992 Mitsubishi Galant VR-4
    awd · manual · Galant VR-4
    Loading...
  2. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Next, I added some clip-ons, then subtracted some more parts for cleaning. I also began prepping the bike to swap in a XV920 motor I picked up locally:
    BrPub3n-JsDHFHN2r_FDwNntFiJqDufU7tdpLgJ9HhybBBbI7e-3mABG1M1topO4zR5fUmuameFS33jXpI=w1006-h566-no.jpg
    Uys-tKP1oq-P2-fvlNuuNB3IjhZHf55hz4e84cCFZDbNicZ8qr3HoJBbOxzyiuE4AHV5HI1fZSik8IZriQ=w1006-h566-no.jpg
    zAlmxy8RzLMCNKIIm0rA1KcPKmhpQWq0RksCv9JJCcWW7E_1-l-Wgoyu_LXEsunXnmJuyrEleDQH_Fmhp4=w1006-h566-no.jpg
    Looking a bit cleaner...:
    7wkxGepgH1dL4HKClhRk7MR5SpAUXLRoAeTmnaPGmB9GInXg7R4TluA6O3_q9i4kcz_5w9kHf6AmBeAJA8=w1006-h566-no.jpg KRxblk-nVyFw2X_I66YZZQfacKrJLR3JeeJI75Zh_vxKO1RXDfPEoeFfKITGd2JNAk_iRUXSmELOzaWc-s=w1006-h566-no.jpg
    hhU5VcSRXiFg6gFBB4vMHAY6rD9bPf5-PDBo2955Yo72rLXjPbgxAJPQsGFl7b6nTRIfwcjr_3bqFjYQu8=w1006-h566-no.jpg mWcEos9JUtuaZB1rPqRiAcTdZq1RbtcYY_af13o4Ni_lR7H6aSfuZ2Nk_YyDENLMQHoYB2Njf-CeyfJhJs=w1006-h566-no.jpg
    On to the seat debacle. I thought I knew how I wanted the shape and look of the seat support to be. so I went to work creating what I had in my head:
    e-mNtXaT3iZ76gCynVLLcSHTY7h1hLahZ1pvD-ciipvTxXyQsIt9YzwVI6tS7fTgqBFl434JDDgNrTM4VA=w1006-h566-no.jpg 8H3PnFCk9ed2oBAuDsz_K98hBy0BnKBl_h1MZEMTr2y4zGyRYuhw-sf93munnOwlUcsk6rr7G6EkQqSXVg=w1006-h566-no.jpg
    kJDmSNm61mqAlASWWqKcZLoMkTS-h5RnVF4eb7bRQKtQxvynBzaykHSIHJ4lQvFY5MgcJaPOAJVsIwNwxg=w1006-h566-no.jpg
    Once the support was mocked up, I went to work on the seat pan, which I made from sculpted MDF and epoxy. Once it was done, I sent it off to upholstery:
    0ZRbUzOqLf-cN36eRkIife3wpeWAJYPd3hJZAshKR1CJqUSITCu1L5OoNSgV_zNwzZ8sqVh6TMyWXAJy5A=w1006-h566-no.jpg hCnJgIzX3Pxx-XQm-rei_nKFBKQh7KZqpilxCI3YOWvh4z1y-k5k001OviMyEI57sIGdOsck4COBrl7UYI=w1006-h566-no.jpg k_fJ1Km-ev-IeHebND8eHqi8gpVwCWK6OmyuKJcg4-H6skAG1F0hBNQH5X0m4_x5hQEUCWJrGnUTXFilpI=w1006-h566-no.jpg mE11O2UGQtYRHcSnhpoeFWg_MfTrpJGu3rnbo3_BzKoPBOPWa-tAu5gijNEAuZeti6ALEDM3xpzrT-ywQc=w1006-h566-no.jpg 5eZGUcp86N4CDbzsIDMWGNhqo20ujou0jOND2gqYQ29dsM7w1ay8drjCA-rGjETn0ynUE-vLwd2Vyt5Rqs=w1006-h566-no.jpg uTZeZBbrhYSIbfPGZVsR6kXxgKfxW2F08vcRd0XHXr_EBZErorcMKZ-m1gYc-C-e_hIIRUxDcViMj_EU2w=w1006-h566-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
    Dstarperformance01 likes this.
  3. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    While I was waiting on upholstery, I got the 920 motor freshened up and swapped into the bike (old 750 motor left, fresh 920 motor right). I also got some parts back from powder, which I installed. Lastly, I installed a XV1100 rear wheel, new rear tire, and fresh brake pads all around:
    gBDLrCFe8F5l0if3mZlnf9C3_3vOkokw3eks2iyxD1ZOkuNPt6HXmZ6MqciVm0g8icZT0XKCuX3St0vOKQ=w1006-h566-no.jpg
    flZWnioTOPzE81zd9NVU4lr7zSMP3LN_Fl3pYnQpGmxjj6n-BJG5fejEZAi-N8-Dm_IRS1Ebfj7DdJou1M=w1006-h566-no.jpg
    yLn-GRZOJ2eFQhDu6Ugfg7EfJk7Jb74KpNzabaAgJQB4qDPiKH0NauZ6WwnKxz4BZO5Q84vye4Q-hIh7iI=w1006-h566-no.jpg
    FKxF7MwXc8mBGwYZ0IoZ49XIj_0Rid5fZyMZswgPl-qUFtDWOzBynoggkcyu0Cdv655lo51LHR7L8McNL08=w353-h626-no.jpg
    dTcrvt4p_gs0u6x23ixlJ-qLf-aG19LuSElqko60roAHU7NCZ5ceSIqKuiLl1L6bjmbxm5_7Na4PULbQM4=w1006-h566-no.jpg
    h37ukceOLawsX4shRd9VnLBc6Hghl57GW6QhXqxUbCcpYFPcs03GgEp_Qo3XXDNRRwHubV2GsCFVsYkvzI=w1006-h566-no.jpg
    n-elf6_PSDjW2qf3WjYdj0HYYtjhYLbG2FBm33VJPE5E_cLvDRKZ2kt9U1RJjJhBAOH_lGnKvKpKslClD1w=w353-h626-no.jpg
    After a few weeks, the upholstery shop finished the seat, and I put everything together. I was a bit disappointed, to say the least. The bike just didn't capture the vision I had in my head. The seat installed on the bike looked decent, but not great. Unwilling to settle, I decided it was time to go back to the drawing board and rebuild the seat support.
    uTLQh01khBfqIHk899-ImyTGJhfi5I4SJVICxB-cZifNuYBBi2hHLd5bVxj8mCKE5Xq8Gs-gfAHK05UBgI=w1006-h396-no.jpg qroDUSLBRPUEAYsgBRJaFJw9F3UmDLeZOyiIaEMoss9194p0DlgudGSklV42izblCVRJHQypQ6fzT-qIi8=w1006-h448-no.jpg WBO9VsbhyPfs19hO9I1_jGxIAgF_s3xQFtFiC9IjGK6pdCNj3o98miEkeYwynjhAm6vW7Dg8n9Ln1nsX8A=w1006-h566-no.jpg
    SVrm7UAK7Q7kt5VOsTM5be-0wgi0nq-QC900Zho-guje9S5W7434Zzdw8BNHF90B7aEDCZYyB6DiALZ8uA=w1006-h566-no.jpg
    TQ2LiEKRa7S_rEbpmpbGHBxY2Lkody8wO5DZPeCs8YcHMAu9oOj--f7XdURQP283JUA8EBbXAiHIHZYnCM=w1006-h566-no.jpg
    eRvxNvl_8_yC9B42a_v9BdKjViS-qZJ9PFg5idCIAf50s9umwjEDSzTlvYDaKrPsG7_trNA_FPdk62VGgM=w1006-h566-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
    Hickory-NC-2Ggsx likes this.
  4. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    So, I went to work on a new seat support, this time looking to do something more modern looking:
    ngBsPaoj68lSSpVeUHhuXk9YflD888ZHjC4k-g7eSWuzeX9dWdoI1CAYQHADi0aJnaxEhAIDMk8gUIIp2I=w1006-h566-no.jpg l6gZNf0zkl9cqlVu9NrBRPjUiRZQSm6SNfZBFL5lytM0UkAzAK8bc3cyykUA46c9PuoLE-jTttXSa_ZhJg=w1006-h566-no.jpg
    Once I had a rough shape, I mocked up the seat again with the new support. And, once again, it fell short of my expectations. I felt like the seat shape itself just wasn't lending to the lines of the bike well. When I initially designed it, I thought the hump on the rear would give some added body on the rear of the tail, but it wasn't jiving with the build in my head. I decided it was time to make some more changes, and scrapped the seat altogether.
    696pcCTcIR2fOu-4-aYXaXdqPvqVBMaboGXwDDAepCuXHGENbxutDqzdYKuGYBTyp59DtgXLwQdqPLQiEM=w1006-h566-no.jpg jJe2EQNIj8RlLbRZ--3yzwC07RfxhDaW724NmTGE8M7V5VJVTyrpSyl3nNabIWEkxTiGmBgZzArXRLJLjw=w1006-h566-no.jpg KYGvk3i6bVWeUV-ZboGqTIcPt2d3tSaBnGm-x_05QT1l07wVwppFBY_q8tlXffv5UDu4_Ynul6rcGSUPG4=w1006-h566-no.jpg ED2J7VZ2CwJELxzwwMz_43GuodMcunpBzhXSVdTBQYbblxCTmyY6TL7SObUZi6W2NmQLY40fNQr8YvhYFM=w1006-h566-no.jpg D84KJ48Eh5xRAmrUm7lz-Q3iyA7ouJgVCym1M3_9eillRn2fDis2qBF5PMJUn9CwbPWN-vmcdG5jZReXo0=w1006-h566-no.jpg
    After looking at some other bikes, I decided I wanted to change the shape of the bike a good bit. To do so, I swapped in a 79' Kawasaki KZ400B fuel tank and new seat. Once I had them mocked up, I knew it was a winning combo. The lines flowed, and the bike was finally coming together like I had originally intended. After adding some final supports and attaching points to the seat support, I bolted everything together. I also added a Cyron Lighting Beast Integrated headlight, which looks awesome.
    JF-2CV-8BMn61wTVrRLbLHkTwsr8UxhaQg82CkCbNEvyB6azdxLEzEAfq-Py7a8KOvYIjtJWaFq2IvvaUg=w1006-h566-no.jpg
    Iyvxu6pwWs2nxYQjHP3-rJGFZkor9GE2cvGj2VVTfFTktr3Xiys0PMDJc9qNu-z7FmpefEHZun1SO2WObk=w1006-h566-no.jpg
    ZWFYxjhCc5tA7tZTNe_Y6jKdNdpJd61kiaqTazK04OwjGMeYxpOKyzFB37YcQ3I_l9J9lTr3R6_eGbJcPM=w1006-h566-no.jpg XYq_Rq7-0P2ymf2sqrlJSpqeeOyMzbFgeGAb3qJE4e8pE0vPwXjKURzbgYToJ9V0Ue6c8S3_jYDQJyxP6wE=w353-h626-no.jpg x-OCqG3wP1y8O9AWxU0eiRP0ilQWjGguYnU0lwOq5933xb9LOrmhcBp0i9ykKNFrTG3rDueTAx9iuIcyQw=w1006-h566-no.jpg FwxMx8VTusCS9m_sleBJFYsj2MSNlM3B7zqSWiKgGsEKKaUt0fPkR0HQuVmQtKdtn1Go0iJWjMYgps0a0w=w1006-h566-no.jpg fZ0kmm1PW7eq8dCw_GOPSqaOP0M55szWp7qyPEyzljxZUnaJ3bwch0dU3gwGdhHzfkkTwajziMq25r8GNY=w1006-h566-no.jpg
    xq456DA4kOmkoQTw0_eFCCuaEWLIxV_kt9vo8qdxO54cKQtyMqIFsZTRi5tjXNTOAjgn0L6UpM8HN4ZjCo=w1006-h566-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
  5. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Once the bike began taking shape, I started adding smaller details. I installed the old factory horns, fuse box, aftermarket rear sets, a carbon fiber front half fender, and some other stuff. These details may not all stay, but I definitely like incorporating some of the cool vintage factory parts back into the build:
    K9GnM3O8sZV0sijHroTZYk9nQpx-sFMRkUz3X5-u0Uu4bprMPfyU1t-NRCUhY-1IBDKQ3h6zf7KltvyYWc=w1006-h566-no.jpg 6araqRDt66aKyCfyvNm26w-u9b6_XHPb6fEq_YQkO2QOUw3p_wiHx0rI_n5uVFO-D1gObWRkIYk7lhvyDs=w1006-h566-no.jpg lMJ8nmjEBGZGy5dvcoELAwn3BJpf_ww-QBRt-SgD1sTw2xANsZh0wgJEiXF2xrN2-7-ofP4gYcq___FyBU=w1006-h566-no.jpg RO2qryAgm195Vk0phxkvlsql8-vWo7QvdFomA6XF3krb-nBE4D5fuz3dDYuQEHyTe7wlTTZksqa4Ac9S2U=w1006-h566-no.jpg Anscl0l-mdwEfpAQcSnnN4WdbMS3rt-I2FVcxQyVg8WIQymP8n2ZZd_O871z-hJIwTSmPXnqhNZOq3bYjs=w1006-h566-no.jpg
    Cleaning up a little by doing little prep work on the tank:
    ke_fqYE4OdGzGmJYZ_tzmd1D7UM9QOidhtg2q4nkVCyK7TO8jwP4EriOd4PHqcBw5jsiiIMgadU24DXlLQ=w1006-h566-no.jpg 4--m_aL_dYvy6K8swrR3CAfU1d-NUHjcuaUnOi88ceFFbzIVqvN9UbW8a1Du2sdLch4r0laF-CkkEe0DM8=w1006-h566-no.jpg u3ASvkDatsmIrOYyUgnCUoefq8EsVcE-eag9MVI3U-qsJijyAC-OPjmxjdo2ze-yOHYVrogWjeMAnGOJx0=w1006-h566-no.jpg F4hhL6A8o1ITIgXt_1Arhy-F3clmWzige--QMo6HrM-OUZ4ZNSyH47pCQzq1XAUfEXyr-jT8jTQxnTqJj8=w1006-h566-no.jpg 0I1rOTpZikShLulF5gfDBeElTUOjNWd3yCVDiPcb8Z32xA_0ngWPzShC5aA86-RP0ZdlDXCu9_t1TjZMFM=w1006-h566-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
    talon77 and Dstarperformance01 like this.
  6. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Torn on what to do about lighting, I decided to try some LED turn and brake lights from Morimoto. I might try and do something fancy with the arrangement in the rear later on, but this will do for now. Morimoto "pindicators" are pictured up front, and their ModPod LEDs are pictured in the rear:
    tXF4o3fTkTsqqcsOUP7bXDIOzf6GjviZq3kquUuT7ifSCY6B_Ew9IBoblU05o86RYEHvEFrJd8KC9kqFkLQ=w353-h626-no.jpg eBsgT0zjIRjBkVxrcQJ2RK7jle_Rv7eUBugY3Kp8jVQVe-oiglVvVGIoszCzz6zF8Y_VS5QqNm-Gk92l1IE=w353-h626-no.jpg -Bslsar2gTxDDUIHXOi0XFtPMlHQyO2Y-sjkmVc5dIex67Y53GU6HRbiXugfcNMzXfmO0Vd6Ou5iC_6cpw=w1006-h566-no.jpg
    Annnnnnd finally, here's the current state of affairs: The bike is half apart, with more parts off to powder:
    7SVO571fdywTG7kIxyD_y1MUusmIbr8EcFtBkY12RTBucVQ7eQrE7djKdMY93Ri9I0RRryRryXzDWVvdgo=w1006-h566-no.jpg
    r7wrhMokIkVZpvtginDQ0XkiIPpzojA5_XJPYOxgGW7gotGiehf8kpnZwj9dz1kPqIl0yHy3pIS6zG3uUN0=w353-h626-no.jpg
    With much of the big stuff knocked out, I've still got some big tasks ahead. Probably next on the list is to clean up the wiring harness and install my Koso D1-OLED gauge display, which will surely be tedious and time consuming. Then, I've also got to bolt on my Mikuni VM34 carbs and tune them up:
    zo_5_RceJ0UdU9iWsvkKCmjSBaA9Py-zHvBCGetij8eF63Uww8Wn5teiDL6DKyuxhruO74NWzeJSzoTpsQ=w1006-h566-no.jpg
    Thanks for reading along. I hope to have some more more updates to post in the near future!
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
  7. brian9397gsx
    brian9397gsx Proven Member
    1,155
    91
    Joined Apr 28, 2008
    sioux city, Iowa
    Wow I was skeptical when I saw virago build. But being a fellow Yamaha owner, I ride a 14 bolt r spec, I had to check it out.
    You did work that looks great and I really like that copper colored tank. That's a great color.
    brian9397gsx
    3K  0
    1993 Mitsubishi Eclipse GSX
    awd · automatic · 1G DSM
    Loading...
    GST with PSI likes this.
  8. 19gsx91
    19gsx91 Proven Member
    946
    292
    Joined Apr 20, 2011
    Walworth, New York
    I'm starting to think this should be what you do when you retire.. small custom builds. It seems be it bike or car you always have a way of adding a unique take on it that could work out very well for you financially.
    Street Build 3K  16
    1992 Mitsubishi Eclipse GSX
    292 whp · 264 lb/ft · 1G DSM
    Loading...
  9. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Thanks, Joe. It's just nuts and bolts. If only building bikes and cars for a living paid the bills...
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
    19gsx91 likes this.
  10. Vegas smith
    Vegas smith Proven Member
    3,122
    1,664
    Joined Dec 2, 2002
    Houston, Texas
    Building a bike seems so much funner (easier) than building a bigass car :)
    Street Build 4K  10
    1993 Eagle Talon TSi AWD
    awd · manual · 1G DSM
    Loading...
  11. 19gsx91
    946
    292
    Joined Apr 20, 2011
    Walworth, New York
    In my case taking them apart pays the bills. :D It's not the nuts and bolts man, the level of detail and ambition. I'm sitting here reading this like THIS MFER BUILT A SEAT!? which should really speak volumes for how deep my laziness runs at this point, that and the daughter steals my time. LOL
    Street Build 3K  16
    Loading...
  12. bastarddsm
    bastarddsm Proven Member
    4,525
    1,074
    Joined Aug 26, 2003
    Mendota, Illinois
    Needs the tank dropped little to hide the frame. Nest build though. I'll try dig up a picture of my rat bike I built in 09.
    Showcar Build 6K  1
    1991 Eagle Talon N/T
    9.805 @ 144.00 · 1G DSM
    Loading...
  13. bastarddsm
    4,525
    1,074
    Joined Aug 26, 2003
    Mendota, Illinois
    Wheels and forks are off a 70s kawasaki 250 Enduro. Engine is a Yamaha Seca 550. Header is parts of a China dsm turbo header. Port spacing is actually really close!! Way too much motor for the chassis/brakes but sounds cool and handles good for a home made on really old tires. Goals of this build were cheap unique and get it running. Has a lot of rough edges to work out. Some day I might. First thing is I need to make a tank for it. Has a plastic dirt bike tank in there now.
    Showcar Build 6K  1
    Loading...
  14. motomattx
    motomattx Proven Member
    2,324
    964
    Joined Dec 9, 2010
    wampum, Pennsylvania
    That engine really needs cv carburetors, those carburetors are designed for a two stroke dirt bike.
    Drag Race Build 4K  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  15. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    It's more fun in the sens that it take me longer to get sick of wrenching on it. It's certainly easier.
    I dig it!
    These are pretty common upgrades for most 4 stroke V-twins. What would you suggest?
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
  16. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Did some more wrenching on the Virago. I installed the Mikuni carbs, threw in some new plugs and got the 920 motor fired up. Sadly, it was blowing smoke, so had to swap the 750 motor back in.
    -p5WXbOBs1sjw9s6IngZkh-cLba3abPnCiulye0qqhYl6KthyizTHiXr5gk_O3ay91m1U8uzEx8GgG6vY0=w1113-h626-no.jpg
    IyJQOp3WyZWwKsPSvPhjyo16-j_KTgiq7EnbS0PztmXo9LdZ5ttZ8Z9mzXW78dlfqip-iUMqcxymz4H6dw4=w353-h626-no.jpg
    5boG6OJhQeZ-uKSt7BhsrrZ1XqlWTtmRS2HyAQ5KrCIFTSX17UaB7rBHXdBnxFz7B8Dbtjl454oIU41Nxs=w1113-h626-no.jpg
    The starters on these bikes are notorious for being a bi***, so I installed a new unit.
    XGfTvuP-UL0FLckr6P89TblUbXSrG-ZiPTG09-FgPJml_dFN67mLc4LuMl-HNeFkNisXPpgKfIpixwCk8U=w1113-h626-no.jpg
    Once the 750 motor was back in, I got to sorting out all the wiring. I picked up a Koso D1-OLED integrated meter, so I needed to wire that in, hide the rest of the harness, and get the speedo wired up and installed.
    Here's the stock Virago cluster compared to the Koso unit, and of the wiring progress.
    PCndrnsPr0cAJpMg2OnA6E7ZQhNFbfNDSJpnb366bg_xFUSy_KH8GFzSinEImDl8zaWIsvXyLKHaVT1Ou4=w1113-h626-no.jpg
    0NSWpaSvQ3Ci3uCcczkoPXUQwEkiZhZAFujVa4vCLYR6WVyMJ9bZdVEIi_F9SbxI4PyUt4dZLjM4BqgK2g=w1113-h626-no.jpg
    z165xp59MHjoXpKrJTV-n7JElz6KVLMoYv0K_Z23Pv95-TDYyLL8mjEsPq8-CqbhvsgOPaTflOKrU-xqc0=w1113-h626-no.jpg
    eynFhIpvx2m4b8tebyuXCrecQiF5dfCgwkfMBxQfUgg-N1VxzgfbrwPW6D7E4jQdQHIbslhoOjUgLMaUPY=w1113-h626-no.jpg
    Got the lights working.
    A-2TZDsciawRWsDHL8NVKzlXXdYUAPXMgr7l4J9q1eHwkGdMbSofaUIOeQDk6CR1yHF3JSktfAJh59K0Mk=w1113-h626-no.jpg
    QkWBhR1y6Lt9f2SWSrf5BO5pzgw7CV91sk_jgeaaoDuYFwf8iUZFpDSFCrzAibMO_V79q2kQETZdVxeCIU=w1113-h626-no.jpg
    ccgl0xxOt6uS_X0QtrVn13jDLrhjabtTq1NW_A1IgIjZ2WNFcS132MccvClaJI2huurGoyVTaGbMsURAefM=w353-h626-no.jpg
    4dSJluYo9KtUQVyylN_QGf2k83m-pmQWfls6pfFVm0zSQbYJtDCXVe17SWBoVIcKTUv5gtQveTCMnDIHe0=w1113-h626-no.jpg
    NRIjWFSCaYtV-mxxaslIx44yqiOWN8bxGoL2rObszdLYdHapRXyHhWdXBFekk7xEWqqbfAGfMmg8j5E1K0=w1113-h626-no.jpg
    9xAHrf9xmcBBNx72-WyGF5PKUresI8PCpHXuVbKYqDNpHAw8maahudT443gfgrmsjg1zW0bNLFmnfC_3RA=w1113-h626-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
  17. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Once the bike was wired up, I did some maintenance stuff, like new front brake pads and final drive oil.
    8fvPnKR3wiNh5y_V4wFC-NiAx3qJJWU2Qo4hbQLdbBOiP6Hj76IADu0nLd6xTW7TDrG6yQyWWPe-qN5duY=w1113-h626-no.jpg
    Z5MK309h7iUNV2EGlRGobA3uNbmmk6dOrn4_SCqTuZ7Knk8kCvOXR0MPNCrgPGzrLeoDAVY6_gKXy876tvg=w353-h626-no.jpg
    QcdcIZGx6dIS-XtRMwwcrdrmRYFFLBpC8ebteOfQ2bg1YKpDat9GhqXxRrsHie8ZjfqcJbxLlQtTatmeM2I=w353-h626-no.jpg
    Got it all buttoned up, and went for a ride!
    dqt--PWCmWzt5bmWkh0yrv7Z4u_7aZfuM_KczQfFJhQzcPzEQ_DGI6NVh__EazADJQ-vaZR3sWk9MQSeBQ=w1113-h626-no.jpg BEV2K_MKx8vSgcqhfGAGUaAn6fPW8xpXSUUWGXQJ4mnmvEW-y0jI4wOsEdDSbULuzWB5Nsv7_lAzuwWGsw=w1113-h626-no.jpg i9xxgVqmr3TdrAx5wm4yU2XBDrNs6sK6tN-LvlpYV8Vil2idCcuiD22TI7QNHyEOBua-RFf4cpSnkqSaV4=w1113-h626-no.jpg IGLM1kpdSdvyIkK6A5XvjbPkCly7TWr1xRy3s_Es-jFYNTPSzf4Ev9vZzuT8NWbpQDaizobGHtwTlpSmQ8=w1113-h626-no.jpg
    Anddddddd, since the Virago is a single seater now, I've got to build the wife her own cafe racer. Picked up a CX500 :cool:
    pSa2T3VgpOrnU9c4mYIkK1kJUURlWV_x9a0Hz6BDEUw-iax2D2WNtrbtYlL1jrUmwX5-w6mSeSZV5i8hsw=w1113-h626-no.jpg
    UqJdnBkWX4ObqfGe1MM43O0FR9vrj3vgAgFio6JM8tpE0iHtj_o8ocmjEtKDe0j4hM3XWw0wjhiu06oM54=w1113-h626-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
    tametalon92 likes this.
  18. bastarddsm
    4,525
    1,074
    Joined Aug 26, 2003
    Mendota, Illinois
    Looking good. Reminds me of a less oil leaking less falling apart version of my buell (95 cyclone).
    The cx500 sound cool, and don't mind jammin gears at 10k, but the one I rode needed 25% more power IMHO, but your drastic weight reduction should help. The stupid shaft drives on these have always been a turn off for me.
    Showcar Build 6K  1
    Loading...
  19. bastarddsm
    4,525
    1,074
    Joined Aug 26, 2003
    Mendota, Illinois
    A mikuni is a mikuni is a mikuni, don't matter what it's for, it's just a little bit of jetting away from being for something else. Personally I'd look for some. Keihin fcr 39s from a 250f.
    Showcar Build 6K  1
    Loading...
  20. motomattx
    2,324
    964
    Joined Dec 9, 2010
    Lol your talking to a Gold level Yamaha tech here, a Mikuni is definitely NOT just a Mikuni, there is no accelerator pumps in a two stroke carburetor, a four stroke need them or a CV style carburetor, and thats the LEAST of the differences, but the first one you will encounter when you go to accelerate and the thing gags on you most of the time.
    Loading...
  21. bastarddsm
    4,525
    1,074
    Joined Aug 26, 2003
    Mendota, Illinois
    Blah blah blah. All your gold level stays means is you can follow directions. Size the carb right and jet it, and its just fine. There were millions of 4 strokes made with a big old round slide and no accelerator pump.
    I pounded out thousands of laps on mx tracks on air cooled 4 stroke 400cc with a 38mm vm round slide and no pump. Was just fine, sure if you lugged it way down low an whacked it open it may bog, but you shouldn't do that anyway if you want to win.
    Showcar Build 6K  1
    Loading...
  22. motomattx
    2,324
    964
    Joined Dec 9, 2010
    Your obviously ignorant of what you speak, Gold level has nothing to do with following any instructions, it means a week stay at Yamaha headquarters in Kenesaw Georgia being tested on bugged machines to see how you go about diagnosing and making repairs to it, every move is scrutinized and only the best make it through. At the time there were only 5 or thereabouts of us in America, I dont know how many there would be now but likely still very few, this isnt some ASE type of certification, nothing like it.
    There were not millions of four strokes made with no accelerator pump, round slide or not doesnt matter, a four stroke needs a CV style carb and or an accelerator pump to run right in all conditions period, do you really believe that companies get their jollies spending money on complicated carburetors if they didnt have to? really man?, just because something worked for you once doesnt make it right or ok for the application, running and running RIGHT are very different things, I can run my car with no fuel system on a can of starting fluid if I want to, that doesnt make it RIGHT or ok. I also have pounded out TENS of thousands of laps on an MX track and held a pro license and a top 100 national number in MX and SX, when I finished racing I decided that I wanted to stay involved in the motorcycle world which is when I took a tech position for Yamaha who had a relationship with me through pro racing and made it a smooth transition for me, so thats my story from then to now, I DO know of what I speak, this is one subject I am an expert on.
    Loading...
  23. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Still wrenching on this thing. I added some new ignition stuff.
    P7kVcSMLHZ4kWkpctcC-osOO-Y5VsVFGZ08mBg92Ba0ZDuRsQeVL_UxEtVf62CJEQrPY2tlBeF5H5nsrHyk=w353-h626-no.jpg
    qJg2COmIAQqEB6znVbgnFcYeG7-Wi1whPp8XH0OF5xCn8iUtYfWKXOSgKNWTkYVsw4kO42xqpy-aLbpU2hw=w969-h626-no.jpg
    Then spent some time tuning the carbs. Got them all sync'd up and running great!
    -anZehQQdjlK0JoJ0Nop4XLCRSO740imuD7dq8HBdRwKDOSACmiAak4qcNjB9yfyC9qbY3tpsqFm5lKJjs=w1113-h626-no.jpg
    TLow74zKouEp-C45Rm1IuOB7GbDDy9WB15EJZ_yzM_dc9jhc2yfKhKH4YVPXKu5y-Y_VzgPmJds24BT1fD8=w999-h626-no.jpg
    While I was screwing with the carbs, I added a set of shorty velocity stacks from Dime City Cycles.
    stom-motorcycle-carburetor-parts-machine-finished-mikuni-vm30-vm32-vm34-shorty-velocity-stacks-1.jpg
    vin-NyOkaCn6pCslRd0AmTe4jnXfg6UOQs6gOQOjH8W9lz3l97rKfj1yVF9rdErofguz3GLaumTtfMexZk=w1113-h626-no.jpg
    -XG6IiaPhuo9MlRiuBvZywd1RX5y_jjH_DhY5AlD5LZypoCbfMVvZircirs2GeaDho8JpZhuNyPna61MQ0=w1113-h626-no.jpg
    4r9uJsl9L3nNinyR9r8jdXBudFt6yD6s_6kjCxPnwCYker-Tl-fPtYxBirYAspUq0cDFgvJJ5DpbKzw7bQ=w1113-h626-no.jpg
    NjLdaYVBRhQwOloQzoNOiujHWbyCjS-_fjGqMs_I345z3TcWRW14dvpnEp5z1iC2czaNWKUnXcPNsZEYnI=w1113-h626-no.jpg
    More maintenance stuff.
    sUYxrLl2GmmoXf2fle_1ssLSNZOKnbOmQTzFuCLe2ZKSkJA-wpc9KXtFlXsTxCzjr0stCtDc3opz8SkA6k=w1113-h626-no.jpg
    And some moar pics out ridin.
    aKrRe3yyRFXqbf8tkgMuMt5mVLU96xdgnnQyROLF9mTVDV6-kDnsV3c7dejBHhA4OK9sQ9DyJ9EmOAPiIE=w1113-h626-no.jpg
    bqFerkXtvxh64TNdGzh12OE2_imdRc1UvFjOqjPWlosRD4cI3X5DYA3sTYauIxQ5jBBT0OIcCp6nS89IYI=w1113-h626-no.jpg
    qsmtI0qKKEH1-Os5MJoi0VLd_4PAXfdHUjWQz-AGoQeOcaoeNu-7OCBRs4cKzFD_gCeWGuGNSxn3BCP7A4=w1113-h626-no.jpg
    NWV2BSICIJ1vcbaGobm64vx43smxGZhhAGx8wetx1DTwHYiUbPh9pJdueAmILi4I_-exBrDfft20dAFoEcE=w353-h626-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
  24. d1prospect
    d1prospect Proven Member
    232
    34
    Joined Mar 14, 2004
    Glen Bunie, Maryland
    Bret, man where do you find the time buddy. Always something sick from your camp. Well done. Looks amazing as usual
    Drag Race Build 4K  15
    Loading...
  25. GST with PSI
    1,816
    1,349
    Joined Jul 27, 2005
    Updates!
    Put some more miles on the build. The motor on had 13k original miles on it, but who knows how long it sat before I got it running. I also put a few hard miles on the bike to make sure she'd hold up :)
    IhysJ8QyiOz3tYoOMakUV5xTs6yZYcOnOYaley1D75b8hJG16ShZMWHwvZZRev21RaEfuQFVvGkRCYapeg=w1112-h626-no.jpg
    z8fvvHK0uR46UIqjAkmNfQ3TCtxHQ8Wpoe0_fArqeCqoev5ivOc_T-CeHIXOUyvpVNmKqGwEKrWorTc4ug=w1112-h626-no.jpg
    IDSUJro8OBdYVZlzSp1L2kORXD7nIOLC4oW9qVkGb_-No5n_XtBQnGM4QYYJViVhoNb-hoYCD0KqpIwH3w=w1112-h626-no.jpg
    z_mvaAw7dqQ_UE7o6TN6wuxsAS1ofFprzyXdjk97P5u_F7IL0irwEMDJYLMOjVcbkSbOfknnXcgYVldpDw=w1112-h626-no.jpg nLG2xLN-yeneKZNwE__6-EawhKiKMaf7QO0-0LQKOKSfLcoSCWpvWKrY3QFvHmONhdExJ_GF5DTvRz10fw=w1112-h626-no.jpg 90r_WsJabqaVa3bYJ_FZCYTwYC-gJKKWAma4s4ZRNU2FPUtq_uWRZ7UJSYQqWNK_Dz23olbA6jqca9PGgw=w1112-h626-no.jpg
    Speaking of hard miles, I decided to put the bike on the dyno to see how far off I was on my carb tune. I see now why people say tuning carbs is an art. It's obviously not nearly as intuitive and doing some third gear pulls and reviewing the ECMlink data on the couch over a beer. Anyways, the bike was a bit on the lean side. I used the data to richen up the tune. I ended up going from a 195 main to a 210, and swapped in a richer needle (6DH4 from a 6DH3).
    xGsvvgnctOjiIsax1Sc0MBncIj-cH_Fn2_UVB4y54rVSmhtAqe0LPhkpBtHHSPY6ZoUntaiMIt70ID0GMg=w1112-h626-no.jpg
    DvhP8L5ICW3-0uTDBN0LXkRzVjcNBQwL3UsTk21q-h_B-LTzc8xSUFpnY7JKZqejT5C6ayZzKxI-i9UGiA=w1112-h626-no.jpg
    IhJNmrBQnsmfC2BOD2tTRgJlX4VoBGeSnn9I1KBSGF3gXXg9LzcJzmBH9CVCkxfudREvDMaWdrr1ivBaMqg=w598-h625-no.jpg
    After changing up the jetting, I synchronized the carbs again.
    2nTAcEp65ObB5nNkS77fU8Wc816v1p6CsS5VbTwqaciwBhdyCtegyF3HUAIVEv5E-itEDL-axbyl5hd_nw=w1112-h626-no.jpg
    KSNRSGyRWc1h3RVeyF-Nc2PYuGZClzu92E_MxUM0Kai9Vnz8UwHYjxbrqu-6c6qm_gTsrtI5o7nQ8AgZr6g=w352-h625-no.jpg
    864  23
    1982 Yamaha Virago
    Street Build 5K  74
    Loading...
    ThunderChild likes this.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
