1. Join the Community!
GST Wing Removal
Posted by The Great White, Aug 17, 2011
Please Support ExtremePSI
Please Support STM Tuned
  1. The Great White
    The Great White Proven Member
    34
    Joined Aug 9, 2011
    Upton, Massachusetts
    So this is sounds stupid of me. I've been searching and can't find an easy answer. I'm in the process of repairing some rust around the rear hatch window. And as I'm sanding i'm thinking to myself how much easier it would be with the spoiler off. I removed four bolts that I thought were holding the spoiler on. But upon removal of those bolts, low and behold, didn't just come right off. Did I remove not enough, too many, or the right bolts? And if so, is there an adhesive that is holding it on, and I just need to yank harder, or does the spoiler slide off in a certain direction? I'm not trying to break it. Sorry, for some this is so simple, but I'm a newb, and can't find the answer.
    451  0
    1997 Mitsubishi Eclipse GST
    · 2G DSM
    Loading...
  2. johng96gst
    johng96gst Proven Member
    88
    Joined Jul 16, 2011
    Westport, Massachusetts
    Im not sure how many bolts there are bud there is a rubber double sided tape between them. Try a little prybar with a rag around it and see if you get any movement if not there may be more bolts.
    262  0
    1996 Mitsubishi Eclipse GST
    · 2G DSM
    Loading...
  3. Quicksilver1695
    Quicksilver1695 Proven Member
    78
    Joined Feb 3, 2009
    McKeesport, Pennsylvania
    there is also two plastic pins that help hold it. just pull up on the wing.
    326  0
    1998 Mitsubishi Eclipse GSX
    manual · 2G DSM
    Loading...
  4. miguelmcv
    miguelmcv Proven Member
    2,061
    57
    Joined May 3, 2009
    Fresno, California
    It looks like you have the 3 peace wing.
    It has a bolt at the middle of the wing, where the light locations is.
    You have to remove the inner Panel to get to it.
    If you have the 1 peace wing, then there are only 4 bolts.
    I hope this helps.
    Street Build 172  1
    1997 Eagle Talon TSi AWD
    awd · automatic · 2G DSM
    2K  0
    1995 Mitsubishi Eclipse GST
    manual · 2G DSM
    Loading...
  5. 98gsxTX
    98gsxTX Proven Member
    32
    Joined Aug 10, 2011
    Amarillo, Texas
    OP: this guy with the double sided rubber tape, the person with the middle bolt and the other with the clips are right, but PLEASE DO NOT use a pry bar! it probably WILL dent your trunk...go to any auto hobby shop or maybe even walmart or something and get a paint safe solvent to remove the tape. then pull a little harder. that should work fine.
    224  0
    · 2G DSM
    Loading...
  6. johng96gst
    88
    Joined Jul 16, 2011
    I'm not saying to use a 3ft. crow bar and jump on it. Just see if you get movement. You can use tools gently sometimes. They sell poly prybars that are used for such applications as this and interior panel removal.
    262  0
    · 2G DSM
    Loading...
  7. The Great White
    34
    Joined Aug 9, 2011
    I have the one piece wing. So I don't have to deal with all those side pieces and middle bolt. But I just wanted to make sure there weren't any more bolts than those four I removed before I start tugging away. I have a heat gun from work I'll use to try and loosen that glue/adhesive up. So I guess we'll see. Hope I don't F*** it up. :D
    451  0
    · 2G DSM
    Loading...
  8. crash89
    crash89 Proven Member
    1,971
    95
    Joined Mar 5, 2008
    Janesville, Wisconsin
    A heat gun should work just fine. But all of these guys have pretty decent advice. I personally would probably use a razor blade or something to cut the tape under the wing.. Thats just me though.
    4K  4
    1999 Mitsubishi Eclipse Spyder GST
    awd · manual · 2G DSM
    3K  10
    11.043 @ 125.92 · 2G DSM
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
