TSiBOLO
- 77
- 12
- Aug 6, 2016
Milford,
Michigan
Any DSMs running the R2’s in a 2.0? I know they are advertised for a stroker. But duration stays the same as S2 with higher lift at 12mm.
You can't compare cams with only the advertised duration numbers. The R2 has 6 degrees more duration at .040" than the S2.Any DSMs running the R2’s in a 2.0? I know they are advertised for a stroker. But duration stays the same as S2 with higher lift at 12mm.
I have no experience with the R2 in a 2.0L. I don't know if this will be of any help, but just speaking of my experience. I was using the Kelford 276/272 12.5mm lift in a 2.0L which is supposed to be their 272 range cams that fit better in a stroker. It was definitely fine in a 2.0L. Just the power band was obviously higher than their 272, so I liked it in the track more than on the street. if it's mainly for streets then maybe you should go with the S2 if you want GSC's cams.I only found Evos running them and a couple were 2.0s. Headgames recommended for me to use them. So just wanted to see if anyone had first hand experience.
