Greddy Turbo Timer Install Question.
Spoolio
730
10
Sep 3, 2003
Port Charlotte, Florida
Well, I have tried searching throughout and cannot come up with much, I was wondering if anyone maybe had a link or knew off the top of their heads where to splice my 3 wires on my greddy turbo timer to the ignition switch wires.
I have found an old diagram from an alarm company but I hooked it up to where it should go but nothing. the only thing it needs is ACC, 12 v, and ON, now, is there anyone out that that can tell me which exact wires need to get spliced into?
I had the same problem, everyone told me to just go buy the wiring harness. Which I did, it took a whole 15-20 to install it. Thats all you do is just plug in a conector and slice one wire into the e-brake cable and your done. The harness is about $15, if I had to install another one I would definitly buy the harness again.
Let me see if I can find it, I know I got the diagram somewhere on my computer.
Alright this thread should help you out.
http://www.dsmtuners.com/forums/newbie-forum/279914-greddy-turbo-timer-install.html
Yea i have been to all those links already, the problem i am running into is the guy before me hacked all those wires up, dont even ask its a long story and lots of wires that go to a custom wideband, full alarm system, and all kinds of other stuff, the only thing i really need to figure out is what wires exactly comming from the ignition switch i need for the 3 wires on the Timer itself, i have found the constant 12v wire, and the 12v that comes on when the ignition is on, i just need to see if i am doing it right, and i need to know the acc. wire.
Alright then me check again, I know I have what your looking for, for a 2G let me see if I can find it for a 1G.
Maybe you should just look into buying the harness, then you know it would be right. So easy just one connection and one wire to splice in.
Have you tried following the directions in the book?
http://www.greddy.com/img/PHP/products/pdf/685.pdf
I think he is saying that he doesnt have a harness, and that someone did a hack job and he doesnt know what wire is what. I didnt have a pigtail on my 93 and I had to hard wire it. Ill post back if I can find what I used.
Do you have a haines or chilton shop manual? All the wiring identification should be in there.
1g Wire Colors and Location:
12v - WHITE at Ignition Harness
IGNITION - BLACK/WHITE at Ignition Harness
ACCESSORY - BLUE/BLACK at Ignition Harness
RED 12V + CONSTANT
BLACK 12V - GROUND
BLUE IG2 GOES TO ACC BLUE/BLACK
GREEN IG1 GOES TO IGNITION ON BLACK/WHITE
GREY HANDBRAKE SWITCH
http://www.dsmtuners.com/forums/art...wiring-colors-locations.html?referrerid=76433
Heres another thread that should help you-
http://www.dsmtuners.com/forums/newbie-forum/264610-turbo-timer-hardwire.html
