Please Support RTM Racing
Please Support ExtremePSI
Great Product!!!
HondaHunter2002
596
May 17, 2002
Windsor_Ontario
i dumped a bottle of the steering stuff into my rack and it got rid of my morning sickness my car was having...
i also added some with my oil on my oil change and i no longer have to change valves oil burning is gone..!! this stuff is awesome in my case.. check it out
www.lucasoil.com
too late to edit.. damn
forgot to mention if u look under testimonials there is a write up with a guy who had same problem as me with a 94 talon...
just wanted to put this site out there for any tuners who may have needed somethin like this..
i had morning sickness pretty bad, within 10 minutes of driving i already noticed the difference in my steering wheel and the hard spots were gone.. with the motor lucus product, it silenced the tick tick tick tick almost instantly..
LOL d00d, you work for them?
That stuff is all over PepBoys, Murray's...
That stuff is really thick and sticky. I wonder how it would work in under 20-degree weather. Probably too thick.
Lucas Oil Stabilizer is a 100% petroleum product formulated to eliminate dry starts and reduce friction, heat and wear. It allows motor oils a higher degree of lubricity which reduces oil consumption and operating temperatures. Use Lucas Oil Stabilizer in gear oil to stop leaks, reduce operating temperatures and increase the life of the gear oil. Since it is pure petroleum, it can safely blend with all other automotive lubricants, even synthetics, ATF and mineral oil. It keeps old engines alive and new engines new.
Mix with synthetics? Synthetics don't burn as fast as natural stuff. I wouldn't mix it. But that's up for a debate anyway...
I used it this past winter when it was literally 10 below a couple days and I naver had any problems with it. Shut-up the ticking and I'm noticing the oil I'm changing is in better shape.
Cool.
I just change my oil with fully synthetic every 1,000 miles or so.
Originally posted by Defiant
Dang, I figured anyone dumping oil that soon would fall for just bringing it over. Sigh, nevermind.
LOL. My oil turns dark quite quickly. I'm runing w/out o2 sensor, maybe too much fuel, but my MAS is gutted... so I don't know.
Maybe it's normal, then again, I drive the crap out of my car now and then.
Once I replace/repair few things, if oil looks cleaner for longer, no more frequent oil changes.
Then again, some of us like to keep our engines extra clean, to whatever extent possible under circumstances.
