Got a question
AWDGUY86
101
Mar 8, 2004
Plainfield, Illinois
I pulled my trannie and the middle axle spins just fine but the lower one is solid as a rock is this normal for a an awd?
Axle, im sure your talking about the splines, one for the Clutch, and one for the T-case. put the trans i gear by hand on the levers. then Turn the Clutch shaft. The t-case shaft should spin, if not. its toast.
