SeaveeDSM
Supporting VIP
- 238
- 37
- Dec 22, 2008
Miami,
Florida
Will be running the car back up to Orlando this Friday to have my friend and Orlando's resident DSM guru Jose Clavijo switch me over to SD. I've been running off the stock 2G MAF with FIC 950 injectors and tuned on E85. The slightly cooler weather and denser air now in late fall has my IDCs too high and I think I'm pushing the MAF hard and want more fuel and I've decided to go ahead and make the switch to SD.
New FIC 1350 Blue Max injector set just arrived tonight. Also putting in a larger 9" K&N cone filter. Jose will be using his TIG welder to install the Intake Air temp sensor on the IC pipe elbow just before the TB. Omni 4-Bar MAP sensor is already installed and wired in to ECU and logged by ECMlink. Also going to be using the SD adapter cable to the present MAF connector. Oh, and while I'm up there we are also putting on a new Fluidampr harmonic balancer but that has nothing to do with the SD switch.
If we have enough time and the place is open Friday we'll do another dyno run to compare the difference after the switch to SD. This time I hope to shoot video of the dyno run and will get it up on youtube.
See my linked time slip by avatar for current dyno results (429WHP and 348 ft lbs torque), and my profile for all mods (already updated the mod list with the new items cited above).
Stay tuned ..... will report back in a few days.
