bryanzomg
- 176
- 20
- May 18, 2015
melrose park,
Illinois
I have the jays 1g relocation kit for gm/Saturn alternator. My alternator is taking a dump does anyone know the part number for it?
AcDelco 335-1036 or use this one LINKI have the jays 1g relocation kit for gm/Saturn alternator. My alternator is taking a dump does anyone know the part number for it?
cool thanks
Can't modify the AcDelco for a 1 wire application ?Note the AcDelco is a standard connector and the Motorcity Reman unit is a 1 wire.
My current setup has one wire from alternator to alternator fuse so I’m assuming that’s what I needMCR can make a 1-wire or 3-wire. Don’t do a 1-wire. There’s no benefit.
BTW, the part number is cs130 I believe.
The 1-wire setup is suboptimal and is only around because it conveniently only requires one wire instead of two. You can make your own 3 wire setup like the factory or just plain use the factory harness if it's still there.My current setup has one wire from alternator to alternator fuse so I’m assuming that’s what I need
