  • Update Your Password Today!
    We have implemented tools to identify member accounts using insecure passwords and will be locking those accounts until their passwords are updated. Don't get locked out of your account - update your password today, and ensure your account has a valid email address on file. Read more here...
Please Support ExtremePSI
Gentlemen, take care of your balls...
barza21
100
23
Oct 11, 2006
Fairbanks, Alaska
Hello!
I am in the process of doing a pretty stock rebuild. After doing some research I found some info on cleaning the crank. Here are some pictures of what came out of my crank after I got it back from a machine shop that had just got done cleaning it... All of that nasty stuff came out of only ONE oil galley. All the other ones were the same way. This could've been bad if I had just assembled the engine without pulling the balls out of the crank. So, PULL THE BALLS! :D
Thanks to BogusSVO for all his helpful advice along this process! :thumb:
h[URL=http://s88.photobucket.com/user/barza21/media/20151010_123546_zpsoyqqwzzw.jpg.html]
[/URL]
***The scale is set to 1".
Boostin_Eagle
Jun 10, 2014
Denver, Colorado
Hello!
h
Thanks for posting, good to know.
BogusSVO
5,891
313
Jul 1, 2009
Pensacola, Florida
You hit them with a tig to shrink the balls, then build up a pull point with weld and pull them out with plyers
911gdsmboostin
390
22
Sep 5, 2014
Irwin, Pennsylvania
I am not disagreeing but I thought metals expanded with heat, is there a video?
Metal does expand with heat. U tug them to make a spot to grab onto with pliers the metal expansion is slight it's not held in with major force is what their saying I believe
BogusSVO
5,891
313
Jul 1, 2009
Pensacola, Florida
They do.. then shrink when they cool, so the ball ends up smaller than when they started.
I have no clue if there is a vid or not. I never made one.
I have done about 300 cranks like this, so it works.
Not just 4g63 & 64 cranks, But Honda B & D cranks, Nissan RB 25 & 26, SR20, KA24
Along with any other cross drilled design rod throw crank.
Also looking at some of the big reman crankshaft companies, they do it too
Just need a tab to pull on once it shrinks.
BogusSVO
5,891
313
Jul 1, 2009
Pensacola, Florida
I have a welder that I take the cranks to, He gets them out for me.
Then I tap and plug the galleys closed.
The factory drills the galleys from the rod throw to the main journal.
It is the passage to allow oil to the rod bearing.
Boosted Fabrication ECM Tuning ExtremePSI Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications MyMitsubishiStore.com RixRacing RockAuto RTM Racing STM Tuned
