Mitsuturbo
- 87
- 5
- Feb 5, 2003
Seattle,
Washington
I have checked for boost leaks, compression, leakdown, wastegate, and BOV. The small 16 that is on the car is about 6 years old, and the turbine housing is showing cracks internally.. I'm running about 9:1 compression, and have a Tial gate, with a Godzilla BOV... 2.5" upper IC pipe, and stock intercooler.
I'm wondering if the stock intercooler is not allowing that much flow, and if maybe the turbo is just worn out... however the turbo compressor housing and wheel look fantastic, and spins great... just as it should.
Has anyone else with a GVR4 had problems with not being able to make over 20 psi with the stock intercooler... or a turbine housing in less than perfect condition?
I personally rebuilt my engine less than 10k miles ago... and my car being as fast as it is reflects that everything seems to be in good working condition, as do the boost leak and compression tests.
Any advice would be appreciated and considered seriously.
Thanks in advance...
Mitsuturbo
1411/2000
Mitsuturbo
1411/2000
